Voltage here is stable @ 127V with summertime peaks of 130V. So far, nothing has blown up.
Let me live in the house beside the road and be a friend to man. |
Here is a picture of my voltage with my space-heater on the lowest setting. The. CTC-25 is quite upset when I first wake it up with the voltage this low.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by TUD1; 12-30-2016 at 10:20 PM. |
What is the lowest setting on the heater? 500 or 750 watts. Take the space heater to another room and check the voltage on the Watt Watcher. That's way too much of a voltage loss! Also, portable electric heaters, should be plugged into a wall receptacle and not into a power strip or extension cord. |
The lowest setting on the space-heater is 1300 watts. I live in the basement with zero insulation in the wall, so it gets really cold in winter and unbearably hot in summer. I recently got a 1970's window A/C unit for summertime. I should probably switch the CTC-25 to the low voltage tap someday.
I made my real living as an electrician, so I'm not a stranger to these problems. |
| Audiokarma |
I was pleasantly surprised to find all the devices in my 13 YO home were properly terminated, even though, they used the lower end devices. |
See what the voltage is like on a different circuit. That much voltage drop is bad news,
Here in Canada we're allowed maximum 3% voltage drop on a circuit. Maybe there's an extension cord burried in the wall or some Other fire waiting to happen... I would quit using that circuit with heavy loads until you sort out what's up |
