Old 06-25-2016, 09:43 PM
Radiotronman's Avatar
Figured out that's coil near the audio output needed tweaked a little and I replaced the audio output tube. There was also a lot of interference in my set I couldn't figure out. I finally narrowed it down to the original telescoping antenna. I unhooked it on the back and the reception issue cleared right up! I'm considering this one restored!
Old 06-26-2016, 05:56 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Lookin good!!
Might tweak the vert lin a bit...... Beaver has a case of cone-head syndrome hehe
SR
Old 06-26-2016, 06:18 PM
I tried and got it better, but too much movement on either the vertical linearity or height and the vertical collapses.
Old 06-27-2016, 01:22 AM
Originally Posted by Radiotronman View Post
too much adjusting of either control will cause the set to quickly collapse to a horizontal line and flicker back.
I wonder if one or both of those controls needs cleaning. Did you ever clean them?
The reason I ask is that sometimes an old potentiometer will behave normally through part of its range, but conk out in other parts where it is gunky or worn out. One way to test this is to disconnect the potentiometer and then measure its resistance while turning it all the way back and forth. This works best with an analog ohmmeter where can watch a needle rather than try to interpret a stream of changing numbers. You should see the resistance change smoothly throughout the entire range of travel.
Or, you can just clean the control and see if that helps. This article has a little section with the basics of cleaning pots:
http://antiqueradio.org/FirstStepsInRestoration.htm
Regards,
Phil's Old Radios
Old 06-27-2016, 04:01 PM
those old pots are often bad, IIRC one or both are WW low ohms with built in range limits. Not to hard to find the correct replacement (you may have to add a limit resistor to be completely safe). You should fix it as its only going to cause issues later.
