Old 07-08-2016, 11:16 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Anyone know where I can find a schematic on the Crosley 348 Swing-A-View?
Old 07-08-2016, 11:29 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
This may be a start: http://www.earlytelevision.org/pdf/c...8cp_manual.pdf
-Steve D.
Old 07-08-2016, 11:47 AM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
IIRC, that set uses a 7F8 for the local oscillator in the tuner, and an unusual IF frequency. Be prepared to buy many, many 7F8s. You'll need to swap them to find the least drift prone example, or else put up with adjusting the fine tuning every few minutes for the first half hour of operation.
Old 07-08-2016, 02:45 PM
vts1134's Avatar
Looking For Time
Originally Posted by Steve D. View Post
It's a good reference, but no schematic there.
Old 07-08-2016, 07:14 PM
Rich12 Rich12 is offline
good for you.. keep us posted
Old 07-09-2016, 12:21 AM
baursam's Avatar
baursam baursam is offline
John, I found it in Riders Volume 2 complete with schematic . Can make a scan when back in office on Monday
Ross
Old 07-11-2016, 12:38 PM
earlyfilm's Avatar
Eternal Member
Try pages 29 and 30 of the above mentioned PDF, for the schematic.
You might have to convert pages 29 & 30 to TIF's before printing, and it will take a very large sheet of paper.
James.
Old 07-11-2016, 01:00 PM
vts1134's Avatar
Looking For Time
James.
I only see 13 pages?
Old 07-11-2016, 02:39 PM
madRad45 madRad45 is offline
Ross
Looks like the Rider Volume 2 info is also on the ETF site, including the schematic...
http://www.earlytelevision.org/pdf/c..._rider_tv2.pdf
Old 07-11-2016, 04:41 PM
earlyfilm's Avatar
Eternal Member
John VTS1134,
There is a problem with some browsers, especially those professionally set up in many business offices: For added security, there is a size limit of a PDF you can directly view on-line.
Go to this page on ETF:
http://www.earlytelevision.org/tv_sc...-h-i-j.html#ge
Select (usually single right click for windows) either GE 901 or 910 and select from the menu that pops-up [Save target as.] (Both the 901 and 910 are the same file)
A new window will then open up. Before you select [Save] note what the file is being named. If it is a random string of numbers and letters, stick "GE-901", or whatever you wish, ahead of the name before you hit save and it will be a lot easier to find.
This will get you around the browser size limit, and ETF should download all forty pages of the factory manual.
John Folsom,
Thanks! I was looking at the pictures of the other 901 at
http://www.theradiofox.com/tv/ge901/index.html
and was expecting to see an RCA type of light barrel, and looked right at the Lucite lens, but did not recognize it without its RCA hardware.
I'll bet that open mirror in the GE makes a nice place for cats to curl up in . . . . . . . but it does make it much easier to clean the mirror, and to accidentally damage the silver surface.
I was surprised at the lack of X-Ray shielding on GE CRT / mirror system.
James
Old 07-11-2016, 06:08 PM
vts1134's Avatar
Looking For Time
James-
I was looking at the Crosley schematic, not the GE. Ross emailed me a good scan of one and I have it printed out on 6 sheets of paper.
Old 07-12-2016, 07:35 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Didn't I send you both of those in the box of Sams? Was pretty sure I did.....
Old 07-12-2016, 07:56 AM
vts1134's Avatar
Looking For Time
You sent the RCA and the GE. I didn't think there was a Sams for the Crosley.
Old 07-12-2016, 10:00 PM
truetone36's Avatar
electronics packrat
I wish I was closer! I like those RCAs.
Old 07-13-2016, 07:09 AM
vts1134's Avatar
Looking For Time
uShip is always an option. They weren't close to me when I found them.
