Use a needle file to file it off. Trying to clip it off with wirecutters will likely break the tube's base, letting the vacuum out.
Don't need to worry about cutting a pin. I have some 1L6 tubes.
The previous owner had put a 1R5 in place. Oddly, it can oscillate at a higher frequency than my T/Os with a 1R5 and is more sensitive. |
Speaking of 1L6 tubes, How do the solid state replacements compare?
SR |
I meant to connect to where the battery hooks up... not in the middle of the string O_o
