Old 03-09-2017, 12:37 PM
Zenith26kc20's Avatar
Have you checked the value of the vertical controls? I had a open vertical centering on a TS-18 that drove me nuts! It had sweep, just bizarre. I had another one with 1/2 the value on vertical centering control. I had to add resistors on each end. Once I did, it worked great.
Old 03-09-2017, 12:54 PM
Both the vert hold and the size are good, ohms wise and the vert centering works correctly. This set is bizarre since I cannot find anything wrong.
Old 03-09-2017, 01:45 PM
Do you still have the mis-matched capacitors in the vertical output?
Are you absolutely positive the vertical circuits are wired correctly?
Do you have a spare vertical oscillator transformer?
Old 03-09-2017, 02:08 PM
I still have the different caps in place but they both test what they should in NF 4.50NF and I went over the SAMs and more then double check everything. Which is the vert oscillator trans T? I may have one from another set. I don't think there is a vert oscillator trans in the ts18.
Old 03-09-2017, 02:18 PM
You are correct... no VOT in the set... sorry !
Old 03-09-2017, 03:02 PM
Is one of the caps in the vertical ceramic ? It's capacitance will change when high voltage is applied causing problems. That's why you should use film or a ceramic cap much larger than what is called for. Swap the two caps around and see if the problem changes.
Old 03-09-2017, 03:20 PM
I thought about switching them around. I did put several red film caps in series and parallel to make .005 but that didn't do anything to help. I have the one white tubular on one side and 2 ceramic 2kv caps on the other side and are equal to the NF of the other but if the capacitance changes with hv then I guess it won't work.
Old 03-09-2017, 04:15 PM
2kV??? those caps should be at least 6kV!
Old 03-09-2017, 04:51 PM
I know 6 kv but I'll post a pic of the screen the way it is and another pic with a .01 cap paralleled with the .004 . This is baffling since it has a bright screen and a decent pic with these caps, which is only one side of the verticle has the ceramic.
Old 03-09-2017, 04:57 PM
Ok here's the pics with the ca and without. And I tried another .004 I made up of film caps, 2 to match the pf. Ok the next post has the other pic.
Old 03-09-2017, 04:59 PM
And the other.
Old 03-09-2017, 05:42 PM
EdKozk2 EdKozk2 is offline
Tinker
Timmy,
Where did you ground the .004 cap, chassis or B- buss. It should be the B- buss.
Ed
Old 03-09-2017, 05:50 PM
Originally Posted by EdKozk2 View Post
Timmy,
Ed
It's grounded to a factory tie strip that's tied to the 6sl7 that's where the .004 is grounded. Nothing was changed was all original where the cap was is where the new one went. The weird thing is upon turning it on for the first time it had a pic that rolled but the hold pot had to be maxed at one end to stop the roll then it went down hill fast to what I have now and it was good with those caps I have in there now . It's on b- not the steel chassis.
Old 03-10-2017, 06:45 AM
Ok there is no more ceramics in the verticle and still after putting together several 2 kv metalized caps in series to make 6kv and the proper NF for this application no change. Is it possible that the 2 ceramics in the horizontal could be causing this even though the horiz works perfect. The ceramics in the horiz are .002 10 kv. My mistake the caps in the horiz are .002 not .001 so I don't think that would make much difference.
Old 03-10-2017, 06:51 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
You need the correct 6kV tubular caps in the vertical circuit to have correct linearity. The mix and match does not work well here.
