Old 05-14-2017, 07:36 PM
Sounds fine to me.
Old 05-14-2017, 09:05 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
That'll work. I tend to do higher in value on paper caps rather than lower, not for any particular reason though. When the paper caps were new, they would have had tolerances no better than 20 percent, and in some cases closer to 50 percent. Either the 0.001 or the 0.0015 would work just fine.
Old 05-15-2017, 08:28 AM
I usually pick the closest value available so I can say it is in closer tolerance than it could have been.
A good habit to be in is to read the color coded values off the physically larger micas...Some are paper in mica's clothing. Usually there is a dot the color of which denotes dielectric type....If a mica has it's value textually printed on it then it is usually a paper cap.
Old 05-22-2017, 11:22 PM
ThePlague ThePlague is offline
Got the horizontal oscillator board recapped! WE GOT HOLD. So far this is the best adjustment vertically I can get. Is there some combination of adjustments I'm missing or would a recap of the Vertical Oscillator board solve this issue? I have no problems getting a vertical hold.
Old 05-22-2017, 11:41 PM
I'd start by replacing all paper caps in the vertical circuits.
After doing that, I'd go to the service manual and look up the adjusters for height and vertical linearity. (Your pictures show a moderate problem with vertical linearity, where objects in the top of the screen are vertically stretched compared to the bottom area.) Note that these adjustments are somewhat interactive, meaning that adjusting linearity may affect the height a bit, and vice versa. You may need to go back and forth between the adjusters a few times to get the height and linearity just right.
Looking pretty good, otherwise.
Phil's Old Radios
Old 05-24-2017, 12:46 AM
I recapped all but one paper capacitor in the vertical oscillation board. I wasn't able to source a .0037uf 1600V replacement. So far it seems to be working well! Better than I would expect from an almost 60 year old tv. It took a little centering adjustment as well to get it about right. There are a few issues I am noticing though. I have a buzz in the speaker depending on a combination of the fine tuning on the channel select and mainly from the contrast control. Along with the contrast control, it is causing issues where depending on what is displayed (usually a lot of white and then black) cause some wave distortion within the image. I am not sure if this is just the nature of the beast with these older tvs or if maybe I need to look into the contrast control and where that leads. Thank you all for the help! Its greatly appreciated.
Old 05-24-2017, 08:26 AM
Zenith26kc20's Avatar
A buzz in the audio when graphics are on the screen using a converter box is very common. The signal from the converter boxes are not as good as NTSC broadcast. I have my converter box feeding a Betamax and that combination works much better.
Old 05-25-2017, 09:20 PM
One thing of note that I can't quite figure out. It hates signals from a VCR. I run my hdmi->av into the vcr, its fine. If I play a tape however, it curves off at the top no matter what I sat my horizontal hold to. Its driving me nuts.
Old 05-25-2017, 10:53 PM
Originally Posted by ThePlague View Post
... If I play a tape however, it curves off at the top no matter what I sat my horizontal hold to.
It's not your TV set. VCR tape playing produces video with timing defects that older TV sets were not designed for and not expected to deal with. The only video they expected to see were from broadcast TV stations, that had timing equipment with tight specs, as the FCC mandated.
Specifically, the VCR produces video that has a major timing error in the horizontal sync timing that happens in the vertical interval. This is when the VCR switches from one video tape head to the other that is mounted in the spinning drum the tape slides over when in play. Your TV is trying to quickly readjust itself to this poor horizontal sync, the result is the curving at the top of the picture. Newer TV sets were designed to be faster at readjusting themselves, but then be less noise immune and be more jittery in noisy reception.
Old 05-25-2017, 11:19 PM
Well that is good to know! Thank you for the information. I was kinda of guessing that it was something to do with the signal from the tape itself. Looks like I'll just being using my amazon firestick and the converter to watch films. Would an RF modulator produce a good enough signal or should I just stick to using the VCR as the converter?
Old 05-27-2017, 11:44 PM
A time base corrector will fix that bend. Some DVRs and DVD-recorders have TBCs built in...Also some Sony S-VHS decks have decent TBCs built in. A friend had some such Sony decks, but they were constantly breaking, and he ended up trading me his 3-4 parts decks (and his busted main deck) for a good deck of another make.
Old 05-31-2017, 02:28 AM
So, even running the signals straight from the hdmi to av converter to a rf modulator I get about an hour or so of play time before the waves start to appear. Adjusting some settings can fix things for awhile, but its no guarantee. What section would be causing this timing issue? I'd rather not shell out 250 bucks for an external TBC. If anything, I will probably just attempt a full recap of the paper capacitors in this TV as it has now become my semi daily driver.
Old 05-31-2017, 09:22 AM
By waviness do you mean to say that with a digital source after a while the top of the screen starts to flag wave in a similar manner to what it does with a VCR?
If so there are a few things I would do: Change the lytics in the power supply (so we know the B+ rails will be stable) if you have not already done so. Make sure all caps in the AGC, sync separator, Horizontal AFC, Horizontal oscillator, and H output have been changed, and make sure all resistors in those stages are within tolerance, also confirm the tubes in those stages are healthy.
After doing that it may be wise to adjust the AGC after it has warmed up long enough for the sync to have gotten wavy. If the AGC is too high or too low sync may be affected. The AGC pot will have a low no signal zone where the picture fades to white, a good zone where sync is strong, and an overload zone where the pic will go negative and loose sync, and the audio may turn to buzz. Generally you turn up till you hit the overload region then back down just past the point where overload symptoms stop (some service lit for some sets specifies 1/4 turn below overload).
Old 05-31-2017, 10:57 AM
That chassis, while being a good performer, has a more basic AGC and not adjustable. I feel, some of those simpler design sets were intended to be used for OTA analogue signals.
Old 05-31-2017, 01:22 PM
Yes, very similar. However the wave issue sometimes appears within the middle of the image depending on what is displayed. Also a little bit of wave on the bottom of the screen can occur. When I get some time I'll have to go through and recap those sections. I have currently already done the horizontal and vertical oscillation boards. Its probably just time to do a full recap in sections as all issues seem to be related to them. As for the tubes, I have no way to check those out sadly.
