Old 05-18-2017, 08:36 AM
Originally Posted by pac.attack76 View Post
I moved the tubes again but only before startup with no change. Can I move them while they're on?
6J10 / 6Z10 are subs & came double marked.
See tuner type ( 175-###) & compare with with manual to be sure
it has the right mix/osc tube. Do not sub, may work but not right.
Turn channels. You should see & hear loud static crashes. If you
do odds are the tuner is dead. If you dont its the IF's.
While running pull one IF tube at a time. Example:
Pull 1st if no effect
Pull 2nd IF & you see & hear things. This means the 3rd is OK
& probably the 2nd is bad.
This is all crude signal injecting & with practice it can show you a lot
in seconds to narrow things down. You can also do tube tapping.
Lightly tap tubes & see if it pops back in. When the set is all fixed you
can also tap them. This can find int shorting tubes & dirty sockets.
Oh yes the hum may or may not be related. Consider it a second
problem for now & ignore it for now.
Old 05-18-2017, 01:17 PM
pac.attack76's Avatar
Stuck in the past
Moved all 3 of them one at a time starting from the back and no changes at all. Also turning the channels doesn't do anything either.
Genesis does what Nintendon't
Old 05-18-2017, 01:35 PM
If you did that with the set on, then there are a few things I could see it being: an AGC issue, bad video detector diode, loss of B+ to the IF system.
Old 05-18-2017, 06:03 PM
Stuck in the past
Set was working when tossed. I doubt the 7 or 8 months of sitting i
outside in the junk pile did it any good. I wanted to try and save it but at the same time, space is limited and I really don't want to put much into it. Not sure what to do at this point.
Old 05-18-2017, 06:11 PM
Stuck in the past
I'm just wondering if the mixer/osc is wrong. It's supposed to have a 6EA8 but the one I have in there has the numbers rubbed off so I can't tell. If I look through my lot and can not find a 6EA8, what is a suitable sub?
Old 05-18-2017, 09:52 PM
6GH8, possibly a 6U8A and 6CQ8 (odd!) as well. Each tube has it's idiosyncrasies, so the sub manuals always have the asterisk or a foot note.
One manufacturer actually made a dual marked 6EA8/6GH8 - but they were short lived, as no other manufacturer jumped on the bandwagon..
http://www.smcelectronics.com/DOWNLO...SUB%201980.PDF
USN RET 22YRS (Avionics/Cal)
Old 05-19-2017, 12:14 AM
Stuck in the past
A life saver as always. I'll check and see if I have any of those.
Old 05-19-2017, 09:48 AM
The correct tube numbers for the tuner should be stamped on the tuner. Most Zenith tuners have this. scrape all the tubes pins with a small flat head screw driver. And hit the tube sockets with Deoxit or some kind of cleaner. It's a pita to do, But if the chassis was outside, all of the sockets Will need to be cleaned.
Old 05-19-2017, 01:50 PM
Stuck in the past
Tried two subs and still the same. Maybe capacitor issue now? Component level. Issues mentioned earlier.
Old 05-19-2017, 07:46 PM
Stuck in the past
Worked on it for the last 3 hours. Caps all check good. Finally did get the static sound along with tuner activity but still hear hum sound and cannot get a pic on screen. Moved if tubes around and changed to different locations. Not sure what else I can do with the resources I have.
