Old 06-10-2017, 08:16 AM
The AFC switches get noisy. So do the pots in the selector.
IIRC it has 2 tuners & a tuner control board. Check the board
for cold joints especially under the connectors. Some tuners
had connectors on them, same deal.
After that its an AFC problem which I doubt........
Old 06-10-2017, 07:16 PM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
Originally Posted by jstout66 View Post
I was worried about that, and was watching this thread to see if a tuner issue cropped up. Those electronic tuners could be a pain in the ass, and were showing problems by the late 80's. It's Electronic, so there is no cleaning.
Start with the obvious... turn the AFC off, tune it in to the strongest signal/pix/ turn the AFC back ON. If it still has the problem, the tuner is a module, and you'll need to replace. If that's the case, let us know which one. It's listed on the schematic.
Ok this is what happened after i did that, I tuned in the pic with the afc off on ch 3, when i would turn on the afc switch , it would detune to a unviewable picture. When i tune in the tuner while the afc is on i get a regular pic for 10/20 mins or so.
as far as the tuner module number i could only find 2 numbers in reference to the tuner, first is 175-5074-01 plant 12 on a sticker on the tuner and 3439626 stamped in red ink on the tuner itself. The diagram on the inside of the cabinet only list the modules on the vertical chassis. I know it says on the module to not use contact cleaner on the tuner but what is the failure mode on these tuners, corosion? can they be repaired? I used to collect and repair watches as a hobby, i think i could dismantle the tuner if i knew what to look for.
Old 06-10-2017, 10:48 PM
dishdude's Avatar
dishdude dishdude is offline
What happens if you just leave AFC off? If you're feeding it through a modulator on channel 3, AFC shouldn't be necessary anyway.
Old 06-11-2017, 09:33 AM
By the book
Turn AFC off
Tune all channels for color pix without "worms"
Turn AFC back on. Should be good for years now.
Even with AFC off the set should work for years OK.
Selector module has only the following IIRC
AFC switch
Channel switch
18 tuning pots
AFC defeat switch ( defeats AFC during channel change )
Trouble shooting:
We did change some for erratic ops IIRC.
Try tuning ch3 on another slot (2 or 4)
Try tapping selector, VHF tuner, TNR control board &
150-190-01 IF module.
Defeat AFC by grounding the blue/white wire at tuner.
Monitor the tuning voltage at tuner. Dont remember color but its
NOT red, yellow or blue/white.
CHECK FOR COLD JOINTS !
CU later Zeno
Old 06-11-2017, 07:45 PM
mr_fixer's Avatar
well last night after trying the text book method that failed on channel 3, i switched the converter output and tv set to ch 4 and tuned in the set, it would detune a couple more times that evening, I fell asleep in my chair watching Svengoolie but as i awoke the next morning the set was still showing a great picture after being on all night. I think i will keep my eyes open for a 175-5074 tuner control "module and the tuner module "is this on the backside of the chassis or is it the long metal box or the left side of the chassis?" and have spares ready if i want to clean/repair these parts. Thanks everyone for their help and suggestions.
Old 06-12-2017, 06:32 AM
jstout66 jstout66 is offline
It's the one that the tuning knob attaches to.
It's been years since I changed one, but it's basically "plug n play",
If it works on CH 4, and stays that way, I wouldn't worry, but if you come across a module I would snag for a spare. The tuner is totally electronic, so there is nothing to corrode. I can't remember what the specific part failed on them, but it was common. Doug Harland would be the one to explain how that works.
Old 01-01-2019, 03:48 AM
mr_fixer's Avatar
Hey everyone!, Sorry for resurrecting a long dead post but i have a new development: over the Holiday week i had a chance to install a new part. On ePay i found a new tuner control... module... selector whatever it is called. My set uses a 175-5074 module and i found a 175-5073 for cheap. The difference is the connectors and the angle of the base plate, It is used to connect it to the cabinet and tuner module which is a 175-2026 module. Well long story short, i found that the mechanical parts "variable resistor boards" are the same. this unit uses printed circuits on a ceramic substrate and are connected via a socket(s)????. I dismantled both units and swapped the new substrates for old and now the set has rock stable channels and has no de-tuning after a few days. Just thought i'd update my latest work with it's outcome. Logan
Old 01-01-2019, 05:17 PM
Well done !
For future reference there are 2 major varactor tuner set-ups
in Zenith CC2 sets.
Early sets used separate UHF & VHF tuners ( 175- ### ) a tuner
control board ( 9-###) & a selector assy ( S-##### ).
Later sets used a big combo U/V tuner ( 175-#### ) & the
selector assy.
If you have more drift resolder the connectors on the big tuner
or if it has a control board on that. If that dont do it pull the tuner & look
for cold joints especially at the shield points.
BTW Selectors were known to drift but I dont know why. We just
swapped out the unit, it was faster & cheaper than troubleshooting
it.
Old 03-15-2019, 08:32 PM
Tim Tress Tim Tress is offline
I was servicing those sets when they were relatively new. The 175-5074 and 175-5082 "tuner packages" were troublesome, and eventually Zenith started selling just the selector switch assembly as a replacement part.
Old 03-16-2019, 01:42 PM
mr_fixer's Avatar
I don't suppose you might remember the zenith part number for the selector switch assembly? I'd like to find a few spares on ePay just in case.
Old 03-16-2019, 05:21 PM
Popester's Avatar
Popester Popester is offline
Also, those models had a neon lamp probably a NE-2 bulb illuminating the channel display. Set looks nice.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 05-26-2019, 11:02 AM
Sorry, but I can't remember the part number; I do think that it started with the letter A, and they called it a "substrate".
Old 08-23-2019, 12:51 PM
freakaftr8's Avatar
Convergence freak!
I've always been curious, did these last model 23v CRTs have the delta gun/dot phosphor CRT or were they inline? I've never seen one up close, but cant imagine why they would tool up for an inline 23v style crt with readily available onlive 25v styles.
Old 08-23-2019, 02:36 PM
Zenith made CCII deltagun 23 and 25" into 1978... inline became an option on CCIIs in 76 IIRC. I believe the system 3 was all inline.
Old 08-24-2019, 04:12 PM
CC2 chassis used delta gun black matrix CRT's 17", 19", 23", 25".
The 13" introed in 1975 ( G line 1976) used a conventional in line CRT
In H line 17" & 19" in line EFL CRT's were used on the better models.
A hand full of them could light up Fenway Park they were so bright...
K line sets marked "System 3" used the EFL in 19" & 25"
L line had the last CC2 delta, a 23" set. All others were EFL
M line was ALL EFL's 13, 19, 23, & 25 inch.
