Old 12-14-2017, 04:40 AM
I looked at the schematic at the ETF website. The only .0015 @ 600 volts is in the boost circuit.
I'd be more interested in the .01 mfd across the sine wave coil. That determines the horiz frequency.
The .0015 you refer to is that the .0012 to ground, was that a typo ?
Old 12-14-2017, 04:42 AM
Originally Posted by EdKozk2 View Post
The .01 uf cap is connected across Coil L16, horizontal waveform adjust. If this is set wrong the picture won't lock horizontally. As dieseljeep noted noted.
The sine wave coil on the schematic I have from ETF shows that coil as L155 unless there is another listed as L16 . The .01 cap across the sine wave coil I changed already with no improvement and I checked the coil it is not open. So it won't be easy to watch 3 images , lol .
Old 12-14-2017, 09:43 AM
It was supposed to be .0012 . It was a typo!
Old 12-14-2017, 09:49 AM
So I did use Micas for the .0012 cap which equals 1201pf and still I have the 3 images and the sine wave coil after turning Alittle bit had no affect unless it has to be turned several times. I also checked the 6.8 meg resistor at that coil not off that much.
