Old 05-09-2018, 03:23 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
So the brightness control that's supposed to be 100k ohms is now about 800k, any idea where to find a replacement as it is also connected to the vert. hold and vert. linearity pots?
Old 05-12-2018, 03:47 PM
Zsuttle's Avatar
Well, I tested the CRT, which produced good emissions after a long warm up from it's 50 year nap. The HV section is producing the needed 10kv for the annode, but still no raster nor indication of life. Any ideas?
Thanks,
Zach
Old 05-12-2018, 06:22 PM
Does it have an Ion trap on the neck of the tube? It might need adjusted.
Old 05-12-2018, 07:11 PM
Zsuttle's Avatar
Would this Ion trap work? It didn't have one but I had a spare from a salvaged crossly TV (10BP4)
Old 05-12-2018, 07:21 PM
What is the crt number?
Old 05-12-2018, 07:25 PM
Zsuttle's Avatar
It's a 14NP4A
Old 05-12-2018, 08:25 PM
The tube does require an ion trap:
https://frank.pocnet.net/sheets/201/1/14NP4.pdf
I have never seen one that looks like the one you pictured... guess it can't hurt to try it.
Old 05-12-2018, 09:01 PM
It requires a single field trap and that's a double. Still might work enough to give you something, you could also try removing one of the magnets from that trap.
It's theoretically possible to damage a tube by running it with a misadjusted trap, keep the brightness control turned down about halfway while experimenting with the trap.
If you get a raster adjust the trap for the maximum brightness and focus.
Old 05-12-2018, 09:03 PM
Zsuttle's Avatar
Great News! After finding an ion trap suitable for the TV, I hesitantly powered the set on and hooked up my DAC hoping for the best. After adjusting the raster for maximum brightness, I then proceeded to mess with all the controls and received this picture.
Thanks for everyone's help with this, this has been a fun first TV repair.
Now to just fix the sound problems, Vertical Compression, and reverse the yoke
Thanks all,
Zach
Old 05-14-2018, 03:32 PM
Zsuttle's Avatar
Quick question, the image appears to be shifted downwards, making it difficult to see the bottom text, and a black bar at the top. I've checked all the resistors in the vertical Linearity circuit, replaced two but still no solution. The raster fills the screen, but TV programs do not. Any ideas where this could be stemming from?
(The rest of the screen is fine, my camera picks it up weird. Picture is also upside down)
Old 05-14-2018, 03:47 PM
Does the yoke have positioning tabs at the rear like those shown in the Marconi TV thread? ( shiny tabs @ 11 o clock and 9 o clock position on the rear of the yoke).
http://www.videokarma.org/attachment...7&d=1526186137
Rotate the two tabs together to change position... change the distance between the two tabs to adjust the strength of the position magnet.
Old 05-14-2018, 04:49 PM
Have you heard of Letterbox movies/TV shows? All newer HD shows are 16x9 aspect ratio and most sources convert them to 4x3 aspect ratio by letterboxing the content...It is a fact of life when trying to fit a rectangular show into a square hole these days.
Old 05-14-2018, 05:21 PM
Zsuttle's Avatar
Yes, thanks, I was able to properly center the image, although the part that covered the yoke is almost disintegrated.
Yes, although I adjusted this tv so that there isn't any space surrounding the newer pictures, I figured that a few cut off areas aren't gonna hurt my viewing experience.
Thanks all,
Zach
