Old 12-19-2019, 02:19 PM
Are there any other 21inch Predicta chassis that use a power transformer? I have never seen a 10L40 chassis.
The 4730 pictured above was 21" and uses a power transformer. I own one. IIRC it uses the same 10L43 chassis that drives the 17" debutante sets.
Old 12-19-2019, 03:56 PM
All the non-swivel top Predictas have power transformers. Like the full dress, Ms American and corner sets.
You don't hear them talked about much but they are Predictas too and use similar chassis inside.
Old 12-20-2019, 11:11 AM
decojoe67's Avatar
I'm fairly sure every predicta bubble top set had a swivel screen. That metal collar at the base of the top could swivel the screen side to side...it was the same on the 17" table sets and the 21" sets....the side arms that look like this should enable tilting the screen up and down are actually non-functional faux decorations on every predicta I've seen in person.
They all swivel side to side about 45 degrees, but the room-divider model was touted as turning 350 degrees. Yes, none can be tilted up and down. That would've have been of much benefit anyway.
Old 12-20-2019, 12:49 PM
My Princess turns about 350 degrees, but my Holiday seems to be only able to turn about 45 degrees in each direction. IIRC, when I was repairing it, i turned the tube around to the rear to make adjustments, but I don’t remember what I did to enable full travel.
Old 12-20-2019, 12:54 PM
Same 350 on my debutante. To enable full rotation loosten the rear set screw...IIRC some sets you also have to lift and turn.
