Old 01-24-2019, 09:46 AM
Originally Posted by SpaceAge View Post
Not sure if an obscure Chinese manufacturer qualifies as a "real" company, but yes Insignia is Best Buy's store brand and the products are built on contract. Hopefully I can get at least 3-4 years of use out of mine, we'll see...
The Insignia and Zenith DTV converters are built by LG. Maybe their TV's are, as well.
I never heard any real grumbling about Viseo sets. Every seems to like them a lot .
Old 01-24-2019, 11:04 AM
That was a common big screw up. Even the early Sonys did it.
You have to read the manual before buying. In my area the stations
are in 4 directions. You have to point the antenna first hoping its on
the sweet spot. Then wait for a channel scan. All your old saved
channels are gone. I miss NTSC !
Originally Posted by Robert Grant View Post
Yes, Insignia is Best Buy's house brand.
My In-laws have an Insignia 39". The speaker is timid but the picture is OK.
If your OTA TV sites are not all in the same direction, avoid this set. It has no manual tuning mode, no add-channel mode, and entering an RF channel won't work. Scanning is the only way to acuire channels.
Old 01-24-2019, 11:39 AM
Get a Zenith DTV converter box go into the menu manually tune the carrier observe the OSD signal strength meter while peaking the antenna then transfer the antenna back to the crappy internal one in your TV.
Old 01-24-2019, 03:32 PM
Tom OM
I gave up on OTA. With ears I only get one station & one other sometimes.
In NTSC days ears would reach out over 100 miles. A big antenna would
get ME, NH, VT, RI, MA, Conn & at nite NY, NJ & PA. all from the average
elevation. Well thats progress ? ........
You know what they say "if its digital its got to be good".
Old 01-24-2019, 04:19 PM
Tom OM
I miss NTSC too...We are probably in the company of most of VK on that.
I'm mostly cable and internet on TV viewing, but I like to DX and play around.... also the family cabin only has access to OTA so I had to get good at grabbing weak signals.
That cabin is so far out in the boonies that the girl who the news says was adbucted and held captive for months was being held a few miles away from there.
Unless you have VHF DTV carriers or are not far enough out to qualify as fringe, rabbit ears are not much better than a foot of random wire jammed in the center of the ant jack...If you want an indoor DTV UHF ant go with a 70s bowtie chop the twinlead off and solder a balun to the feed point with the shortest leads possible.... I was able to best a new expensive amplified antenna relatives bought for the family cabin by a good margin with that 2 buck rig.
BTW if OM was supposed to mean old man I'm still a long way from reaching that title.
Old 01-27-2019, 08:11 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
I own a LG set, a 32" and it's over 4 years old. Excellent picture (720p). Not one problem with it ever. And it's a high hours daily watcher. The Zenith 40" flat panel in the other house, reliable, mom watches it many hours, not one problem. I'd buy another LG set if I needed to replace one.
Old 01-28-2019, 02:01 PM
Robert Grant's Avatar
Originally Posted by WhiskeyRebel View Post
We don't view OTA. Our reception with an indoor passive antenna is awful. Dunno if boosting would help or just provide stronger noise. I think I'd need an attic or rooftop antenna to pull in stations clearly.
Digital TV is not always easy, but there are often workarounds.
If you're within 30 miles of your local full-power stations (15 from LPTV stations), you are less likely to have a problem with weak signals than with multipath.
Go to a website that shows the locations of TV transmitter sites (e.g. tvfool.com) to find out where the TV stations are (in relation to where you are). If you find that your main TV is in a room that faces AWAY from the local stations, and you want to use an indoor antenna, consider placing an antenna in a window facing the stations, install an amplifier, and drill a hole in the floor to lead the cable though the basement or the crawlspace, to a splitter, which will allow you to feed several sets. An attic antenna can feed such a system as well if not better.
Also pay attention to the actual (RF) channels all your local stations will be on. If the're all on actual channel 14 or above, a small antenna may be able to receive all of them. If any of them are 7 through 13, you'll want an antenna with High-VHF capability (you may still get the H-VHF stations, if you're VERY close). If any are on 2 through 6, you'll need an all-channel antenna, which must be installed outdoors or in the attic.
Old 02-07-2019, 10:40 AM
The sound on some of these lower-end sets is pathetic! The speakers are really tiny. My brother had one of those sets and I hooked up one of those computer sound systems, small left and right speakers and a larger sub-woofer. It sounded a lot better!
Old 02-27-2019, 07:35 AM
A smart TV I can deal with
https://www.youtube.com/watch?v=4SJ9CP6nmfs
You could learn every function before you finished 2 beers.
Software was thought out so even a 95 year old could run it.
Old 02-27-2019, 12:17 PM
Z = MC squared
