Try looking up the 12S model. It should be very similar. |
That page is listing the alignment for 7B01, 8B01 and 10B01,2. The 10B01 procedure is rather involved because of all the bands. |
Just finished aligning it, a tedious hour, but it needed to be done and sounds a lot better. Quick question, What year did Zenith switch over to rubber coated wire? Cause man, I dunno if I can do another one of these.
"If it isn't broke, you aren't trying hard enough" |
It wasn't a hard switch but more I a transition.... I have had a few consoles with the same chassis where 1 had maybe 5 to 10 percent rubber wiring and others where that ratio was reversed.....Z Zenith consoles with roomy underchassis ain't bad, but table sets and other brands where they packed every square inch and layered things randomly it is almost easier to harvest the coils and set specific parts and build a new chassis from scratch.
