Old 06-08-2019, 04:51 PM
Not following what you mean by "the ground wire plug that goes into the turntable." Do you mean the place where the ground wire connects?
What I mean is that the ground wire is removable from the back of the record player because it plugs into the back of the turntable using a banana plug, and when I disconnect the banana plug end of the ground wire from the back of the turntable but the spade end is still connected to the ground screw on the receiver the hum goes away until I touch the banana plug tip with my fingers then it hums again.
Old 06-08-2019, 04:53 PM
Also, if the power plug for the turntable is not polarized, have you tried turning it around?
No the plug isn't polarized and no I haven't tried switching it around yet. I'll give it a try though.
Old 06-09-2019, 01:15 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Are you connecting the turntable ground wire to the ground screw on your amplifier, or to earth ground? It needs to go only to the amplifier, any other connection will make hum.
Also, shure cartridges sometimes strap one negative terminal to chassis ground, meaning if it does not hum with the ground wire disconnected leave it disconnected. This isn't a safety ground, it's just for hum reduction
Old 06-09-2019, 07:50 AM
WISCOJIM WISCOJIM is offline
Is this a ground loop issue? https://www.ebay.com/itm/202687458692
Old 06-09-2019, 09:29 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Not just Shure does that. Most all MM cartridges come with that strap to ground at one of the G terminals. If the tone arm head shell is metal or plastic with a ground to the cartridge body, that strap can sometimes cause a ground loop and hum. Remove that strap if using a metal or grounded head shell.
Old 06-09-2019, 10:13 AM
Pretty sure he said it was a p-mount cartridge...Those have no head shell...The cart plugs into the end of the arm shaft like a head shell. There should be no user configurable wiring on the cart since P-mount carts all had a standard 4-pin plug on the back that mated to a standard socket on the arm.
Old 06-09-2019, 10:16 AM
Ed in Tx's Avatar
Ah I missed that.
Old 06-09-2019, 12:30 PM
It's attached to the ground screw on the back of the receiver near the phono input jacks.
I could see about disconnecting the ground wire and seeing if that helps.
Old 06-10-2019, 08:38 PM
OK So a Little update, I changed the RCA Cable that I was using for another cable I had laying around that was shorter and the hum went away and its working fine now.
I think what the deal was was that the the cable I was using had a defective ground wire connection somewhere in the cabling becuse if you didn't have the wire positioned a certain way the receiver would hum really loudly with a 60 Hz hum that was louder than the music that would happen even without the record player playing.
So I think it was mostly defective wiring more than anything.
Old 06-10-2019, 09:53 PM
old_tv_nut old_tv_nut is online now
I hope you cut it in two and threw it away so you are never tempted to try it again.
Old 06-10-2019, 10:21 PM
Oh Definitely, I'm planning on getting rid of that cable!
