Old 07-31-2019, 10:07 AM
During the phase-in of ATSC, there were precise offsets applied to minimize interference into analog stations. This was needed because of ATSC's use of a pilot carrier near the lower edge of the 6 Mhz channel. Offsets were controlled not only for co-channel, but anylowe r adjacent NTSC channel as well. ATSC 3.0, like DVB, uses COFDM, with multiple pilots at the same level as data scattered over the band, so the signal is very noise-like and no visible pilot beats would appear in an analog set. Of course, precision lock between ATSC transmitters is required if they are part of a single-frequency network (use of multiple transmitters to cover an area with a single broadcast on the same frequency), just as it is/would be with DVB.
Old 07-31-2019, 11:04 AM
Analog NTSC co-channel stations were offset by 10 kHz, which turned the interference from a wavering picture into horizontal sine wave "venetian blinds."
At least one company sold a filter that plugged into the back of a monochrome TV CRT (and the socket then plugged into the filter), which contained 10 kHz traps for the grid and/or cathode leads.
I don't know the electrical details, but I have seen pictures of one. Thought I might have a picture, but can't find one.
Old 07-31-2019, 01:41 PM
ppppenguin's Avatar
Band planning for digital TV systems is very different to analogue. As others have said, a COFDM signal is very much like white noise over the entire channel. Single frequency networks are possible though not always used. There is no particular need to worry about adjacent channels.
If you're using analogue TV RF signals in your system (vintage or otherwise) then try to avoid any local digital channels. They look like white noise to an analogue set and a strong local digital signal can give you a very noisy picture. We suffered this problem at the Vintage Wireless Museum, London, when a new COFDM multiplex started up from the main high power TX at Crystal Palace little more than a mile away. We had to change to a different channel at the museum.
Old 08-01-2019, 01:24 PM
Robert Grant's Avatar
To be effective, it would also need a 20kHz trap for when a plus offset and a minus offset station collide.
Old 08-06-2019, 07:26 PM
In the good old NTSC days WESH was the most common DX station
to be picked up in New England. Always in there with the slightest
sporatic-E. No other did this, it would be random from certain areas.
I wonder if you lived in Hartford or Philly.
WEDU (Tampa, channel 3) was ultra-common, too, but WFSB or KYW have have drowned WEDU out.
Sporadic-E propagation in the VHF-Low TV band strongly favors paths of 1,000 miles (1,600 km), not much further, and not much shorter. If a TV DXer gets a station 350 miles distant, he/she will brag about it.
Old 05-31-2024, 08:42 AM
Colly0410 Colly0410 is offline
Originally Posted by ppppenguin View Post
Frequency planning in the UK has always had to be co-ordinated with France, Belgium and Holland. Again back in the says of 405 lines on VHF, viewers on the south coast of England were often troubled by interference from French stations. Usually in periods of settled weather when the troposphere would happily propagate Band I frequencies further than usual. Because the French 819 system used almost exactly twice the line scan rate of 405 you could resolve them on a 405 set but with 2 pictures side by side.
I remember watching a snowy French ORTF side by side picture on channel 3 or 5 in the 1960's, of course there was no sound just a loud buzzing noise.Where I lived in Nottingham I used to often pick up BBC London on channel 1, BBC Scotland or BBC South on channel 3, BBC South West on channel 5 & BBC Wales on channel 6...
I sometimes pick up distant stations on FM, but the band round here is crammed full of high power national stations & lower power local stations. The bit lower than 88.3 is free & I often pick up European stations down there. I now usually use internet radio in the living room, digital+ radio in the car, also have a digital+ radio clock for the bedroom...
Old 05-31-2024, 05:04 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
Tampa Bay, Florida had two ABC affiliate stations in one market. Channel 10 for North Tampa and Channel 40 for South Tampa. People bought special Antenna Kits with two antennas, called "Tampa Bay Special". That would be for one antenna pointed North and the other pointed East. Orlando had a Special too. Big Yagi cut to channel 2, regular pointed at Christmas...
Old 06-02-2024, 08:08 AM
Read somewhere that they had a 'mid Florida special' antenna setup. When I rented an apt in Miami in the late 1980's I had a rabbit ears on top of the TV that got near perfect (just a bit of ghosting) pictures on channels 2,4,6,7 & 10, all UHF stations were very noisy...
Old 06-03-2024, 07:49 AM
Originally Posted by NowhereMan 1966 View Post
I know, I live 8 miles north of Wheeling, WV on the Ohio side of the Ohio River and one station that plays a lot of 70's and 80's music, I love the 80's, is on 105.5 Mc, WUKL Bethlehem, WV, but when I drive to work in the Pittsburgh area, I get about 4 or 5 miles into PA and the translator they have on 105.5 Mc in Pittsburgh takes over and it is from 104.3 Mc, a Froggy country music station.
When Mom and I went to California in 1987 and drove from Frisco to LA on I-5 in the San Jouquin Valley, there were many FM stations going back and forth on the capture effect, the FM band was a pain in the butt to listen to.
FM stations have also this issue here I live (Brazilian triple border with Argentina and Paraguay; Foz do Iguaçu). Besides some pirate station playing havoc with my 70's-80's-90's preferred station, some legal stations are crowded one adjacent or almost to each other (bad planning and communications between countries). Well, for poor stations, it's favorite sport is to change frequency from time to time. And, the radio comms cannot use VHF band due to harmonic interference from poor stations; where I work, the private radio comm network needed to be UHF.
Also from TV analogue era, was common to have some TV channels adjacent being used (4-5, 8-9, 12-13 for example). For this, the solution of rotating the antenna applies, due to different country station location.
Old 06-08-2024, 05:43 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
True, that is a big problem in border area, radio signal travel across the border no problem and sometimes there can be interference with both or all nations if they do not share the same or similar band plans. I know if I past Mercer County, PA ( Mercer County, on Mom's side, my ancestors was among the first settlers there after fighting the American Revolution) and north, as an amateur I can to be careful since I would be above "Line A" and prohibited from transmitting on 420 - 430 Mc because in Canada that is used for different purposes than amateur radio. I was also above Line A when I was eclipse chasing in April and ended in Ashtabula County, Ohio.
BTW, WTAE-TV, channel 4 in the analogue days was one of those Class B (IIRC) low power VHF stations in Pittsburgh. VHF-Lo TV stations from channels 2 to 6 can transmit up to 100 kW but WTAE-TV was restricted to 50 kW because there was a Channel 4 in Washington DC (When WTAE-TV went off the air, many a night, I could get the Washington, DC station, WRC) O the other side, there was a channel 4 in Columbus, Ohio so Pittsburgh was in between. I lived in the West Hills of Pittsburgh and WTAE-TV had their transmitter East of Pittsburgh so there were times it was hard to get over the air, it was a true challenge plus I also lived near the airport, a busy flight pattern. There was an adjacent Channel 5 too, WDTV to the south in Bridgeport, West Virginia.
WTAE-TV went on the air in 1958, until then, except for a brief time with a weak UHF station, Pittsburgh only had KDKA-TV which was WDTV (until the West Virginian TV station took those call letter later on, but Pittsburgh was on the Dumont Network and was said to be the belt buckle. There were people who tried to pull in TV stations from adjacent TV markets such as Steubenville, Ohio, Wheeling, West Virginia and Johnstown, PA too.
One of WTAE-TV first shows, a huge part of Pittsburgh history, was called Top Banana, Second Banana and the Musician that was al ocal variety show. The musician was named Joe Negri who was also the first musical director on WTAE-TV. He is a jazz guitarist and a local legend, he played the Handyman in Mr. Roger's neighborhood. He turns 98 in two days, he got his first start in radio at the age of 3 (been performing on radio since 1929), still performs, still teaches music. Married to the same wife for 70 years too.
Another Pittsburgh TV oddity was we had two NET/PBS stations, WQED on channel 13 and WQEX of channel 16. Joe Negri performed on them too. Pittsburgh was the last US city to still have an all black and white TV station and WQEX was it. It was low budget, using al old 1953 vintage UHF TV transmitter up till it died in 1986. A lot of them ore far our programs ended up there plus a lot of British TV shows too. I was like Brit Box before Brit Box, albeit in black and white. I remember watching Dr. Who and Black Adder on it.In 1986 when they got s new transmitter, they went to color.
Sorry I went long but I love history and Pittsburgh does have a vivid TV/radio history like most places in the world. I also like to go to Youtube to see what TV is like in other nations too, it is fascinating.
Old 06-21-2024, 04:54 PM
DavGoodlin's Avatar
Motorola Minion
In SE PA, 100+ miles from both NYC metro and Wash DC, with decent regular reception from Baltimore's 2-11-13 at 75 miles to SW, either set of big-city channels 2-4-5-7-9-11-13 could be received on summer mornings/after sunsets during heatwaves.
A fast-moving thunderstorm rolling through brought out some incredible mid-Atlantic reception, but not anything from west and rarely from north. The rotor was very helpful in nulling out the co-channel using a JFD medium sized LP VHF only 10 feet above the roof.
Once while testing a smaller VHF antenna in the yard, WPBT-2 Miami over 1000 miles away, wiped out WMAR-2 one muggy summer morning in '78, later WPTV-5 in West palm beach showed up as I was afraid to turn the 19" GE BW off. No great reception equipment employed so it was deemed miracle it was then. What made it really odd was the usual co-channel "venetian blinds" and audible beat frequencies were absent.
Most cable companies in Eastern PA had issues with WTNH New Haven and WTIC Hartford messing with Philly's KYW-3, WPVI-6, WCAU-10. WHYY-12 had some areas N of Allentown receive its duplicate WBNG-12 Binghamton, received normally in most of NE PA.
WGAL-8 near my location, the only VHF channel between Philadelphia's quad and Altoona (10)-Johnstown (6 and 8)-State College (3). Those "upstate" Pa channels never interfered or were received in areas east of the Appalachians.
-Dave G
