Old 11-10-2019, 10:22 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
If you have a .22 and .03 you can wire them in parallel. Some restorers get pissy when they see it but it works fine.
Some restorers wouldn't like me at all. I never re-stuff capacitors, except Bakelite blocks. My CTC21 still has the original multisection electrolytics attached to the chassis, but the leads are cut off and the new discrete electrolytics are under the chassis
And I woulda just used a .22 or .27uf cap, it's probably just used for a tone control/bypass/coupling anyways. Only the silver mica picofarad capacitors in the tuning/IF circuit have to be exact.
Old 11-10-2019, 11:44 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Fortunately, i found a .25 in my odd cap batch. In fact, i found useful matches from previous builds where i ordered extras..
The radio in question is a Fairbanks Morse model 56.. Now all i need is a safety cap for the line to chassis. I was thinking of yanking a pair out of a DIRECTV DVR power supply board i have been scavenging parts from..
SR
Old 11-11-2019, 09:10 AM
How perfect the recap job needs to be for a restoration depends on how desirable/important the set. My best stuff I restuff with quality new parts, worthless trash I want to play with gets used caps pulled from junked BPC sets lazily tacked in...and there's plenty of shades in-between.
Old 11-11-2019, 01:23 PM
dtvmcdonald's Avatar
SR
The .25 is a filter and decoupling cap for the fixed grid bias. It really does need
to be that big, but whether its 0.22 or 0.25 or 0.27 is immaterial.
Old 11-17-2019, 02:25 PM
Never had a radio act negatively with a new 6A7 installed.. It receives better with the old one. (new tube makes it whistle around certain areas of the SW tuning spectrum....... And the new tube tests strong with no shorts..
That and the fact the volume is still pretty loud in the Minimum position.. An odd acting radio i must say, but its alive..
SR
