How so? In his political commentaries, or his fluency in spontaneous glossalalia?
On the plus side these are relatively common and small enough shipping is feasible. It's not that hard to line up and slide on a base with only 5 or 6 pins. I've done it a few times. I've only needed extension wires for 14 pin 7JP4s. I've also files away glass to repair a broken off lead. Nerve wracking but not impossible |
Thanks. I've done about a dozen of them. Which series are you referring too?
| Audiokarma |
https://www.youtube.com/watch?v=ME-w0KFQ-Io&t=144s |
https://antiqueradio.org/CapehartFar...Television.htm Not suitable for every case, and silver-filled epoxy isn't cheap, but it worked here. Phil Nelson Phil's Old Radios https://antiqueradio.org/index.html
