Old 11-05-2023, 01:29 PM
DVtyro DVtyro is offline
Kineskope frame rate
What frame rate did they use for kineskope? Wikipedia says, it was 24 fps with the shutter modified to better match 30i, if this is true I wonder why did not they use 30 fps. Just to save film? To make it compatible with projectors? I suppose in Europe they used 25 fps?
I suppose, running film at 60 fps was too expensive? Was it even technically feasible to map each field into a film frame back then?
