Old 03-02-2024, 08:57 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
This sounds very much like good diodes - conducting one way and open circuit (resistance out of range on your meter) the other way.
Is the reading "1" what you get with the meter disconnected from everything?
Thank you for chiming in there, OTN!
So, if the "1" he sees actually means no continuity then, pac, 1) what is the "reading" you are getting in the other direction on those two diodes? Exactly?
And, at the risk of going too far too fast, 2) what do you get when you check the other four diodes nearby: DP001, 002, 003 and 004?
Old 03-13-2024, 10:04 PM
pac.attack76's Avatar
Stuck in the past
Yes, with leads on nothing shows a 1 on the left.
Genesis does what Nintendon't
