Old 04-01-2024, 10:07 AM
Vertical deflection timing cap
In a solid state b&w TV set is there a vertical timing capacitor that is not an electrolytic cap. If it does and the cap opens or shorts would that likely stop the horizontal deflection as well. This tv I’m working on has an ic chip that controls both I’m trying to determine if the ic is bad or a possible cap. It had vertical but was flickering in and out then both went dead.
