Old 05-02-2024, 07:09 PM
Penthode's Avatar
Penthode Penthode is offline
Originally Posted by Madeline12 View Post
This is not a 19T8 tube. It’s a 6T8 technically… and I’m not sure frankly, it’s just how I’ve followed the schematic. Maybe someone can provide further input.
The 19T8 is exactly the same as a 6T8 except for the filament voltage and current. It is simply the series filament string version.
The choke value is not critical. I would be curious if the circuit did anything
It's purpose is to further limit and if let open, I would be curious if there was any noticable increase in ontercarrier buzz.
Old 05-03-2024, 02:00 AM
dtvmcdonald's Avatar
It is presumably 4.5 MHZ. Go to Mouser, look at Inductors, search Miller or Bournes, axial lead.
Pretty much any of the little series lead ones with a 75 to 200 uH value and a self resonant frequency (SRF) greater than 12 MHz will work.
Old 05-03-2024, 07:09 AM
Well, it seems that the original part is still viable, provided that it's kept safe from future corrosion and oxidation, thus I mentioned sealing it with enamel such as corona dope, cause if it indeed still good, once sealed, it should be good for another 30-40 years or more!
