Old 05-27-2024, 07:03 AM
kvflyer kvflyer is offline
My approach is change papers, out of tolerance resistors and if it still has problems and they relate to stages with micas change the micas last.
This ^^^
Old 05-28-2024, 12:44 PM
I was told not to touch those mica caps when I did my FADA, as it would all but guarantee a IF alignment would be needed, but I did replace the 1500pf ones on the cathodes.
They are coupling caps and should not significantly affect the alignment. After finding bad ones in several 630TS, and 721TS sets I started replacing them more aggressively.
Those 1500pF caps are ceramic and very reliable. I'm surprised you needed to replace them.
Old 05-28-2024, 01:47 PM
the set spent many years in musty damp basement before I got it, even after replacing the 150 ohm resistors on the IF string, (they were way out of tol) I was still having trouble getting the +135 to make it to the far end of the string to the 1st if and tuner, so i changed out the 1500pf caps, that brought up the bias significantly, I did not at the time, have a way to test them for leakage.
And as mentioned, the Mica ones are still in there.
Old 05-28-2024, 04:10 PM
It was THESE little buggers that caused me so much trouble in my FADA!
Not so much these, they seemed OK. and were left in!
