Old 09-26-2026, 01:01 PM
vol.2's Avatar
vol.2 vol.2 is offline
Originally Posted by ostlar View Post
Yes the short is gone after removing the flyback, I tested the resistors and capacitors in the circuit and they were fine.
I'm probably just going to send it with a new flyback and hope for the best.
FWIW, when I said that you should check the short condition with the flyback out of circuit, I didn't mean you should test the components.
I meant that you should verify that all short conditions are gone in the circuit by testing continuity to ground from the various points in the circuit that you initially noticed the short condition.
If you still have a weird reading, then you've still got a short present somewhere, regardless if your components test out okay in the immediate area.
Old 09-28-2026, 02:28 AM
ostlar's Avatar
ostlar ostlar is offline
Just winging it
Yes, that's exactly what I did. I have verified that all the short conditions are gone in the circuit by doing the same measurements as I did initially. The fault is definitely in the flyback.
I'll have to wait for the new flyback to test it, and I will report back on how it goes.
Old 09-28-2026, 12:50 PM
vol.2's Avatar
Okay cool cool. Yes, I would be interested to know how things go from there.
