Old 04-15-2005, 09:25 AM
polaraman's Avatar
<--1956 300B
It is easier to call them.
polaraman
Old 04-15-2005, 09:27 AM
I think the CRT is gonna pose a TINY bit of a problem....Even for all the technical help available here...<grin>-Sandy G.
Old 04-15-2005, 09:56 AM
Tim's Avatar
Tim Tim is offline
I looked at the knob photo posted by Blue Lateral and may be able to help with the knob if I had some more info.
Is the VHF knob metal or plastic? Is it for a 1/4" flat shaft? What is the diameter? Assuming there is an extension on the knob rear that goes into the cabinet, approximately how long is that extension? If it is the same as the UHF knob, that you mentioned you do not need, can you post a photo of the rear of that knob? Anyone have a Photo of the rear?
Tim
Old 04-15-2005, 12:05 PM
jstout66 jstout66 is offline
Frenchy. I just got a spare flyback for my CTC-16L from Moyers about a month ago. It's RCA part number # 113992
Old 04-15-2005, 12:10 PM
Frenchy, I just re-read your post. Do you have a CTC-16XL or a CTC-16L ? They are different flybacks. If you have a CTC-16XL (which uses a 2AV2) it's RCA part number #115843 The CTC-16L is an earlier production run and uses a 1V2.
Old 04-15-2005, 05:03 PM
frenchy frenchy is offline
Frenchy
It's an XL...I typed in 115843 under RCA on Moyer and nothing found so I guess no more (?)
thanks...Frenchy
Old 04-15-2005, 05:15 PM
polaraman's Avatar
<--1956 300B
Frenchy,
I have ordered three Flybacks from Moyers and all were Thordarson. None have been an RCA brand Flyback. The Thordarson cross is a FLY 278 with the 115843 RCA part number. I have a Thordarson book that I got the number from. Call them and talk to Bill. He is the son of the man that started the business. They have 3 or 4 locations that stuff is spread out.
polaraman
Old 04-15-2005, 05:17 PM
Frenchy, They have it. They had a few of them last month. The website search engine isn't referenced to their RCA parts. If I remember correctly, it was around $35.00. Their number is: 1-800-577-6001
Frenchy
ok I will email them, thanks!...Frenchy
Old 04-15-2005, 05:32 PM
polaraman's Avatar
<--1956 300B
This is the back of the UHF knob. The first extention to the VHF fine tune knob has a 1/2" extention. Not counting the part the the fine tune knob hooks to the tuner. The knob is metal.
polaraman
Old 04-15-2005, 05:35 PM
polaraman's Avatar
<--1956 300B
The VHF fine tune knob.
Sandy G - The new CRT is in my storage area.
polaraman
Old 04-15-2005, 07:50 PM
Tony V's Avatar
Tony V Tony V is offline
Frenchy,
Either email them or give them a call. Others will vouch with me that they are very friendly and excellent in every way to help you with your order and most importantly know exactly what you are looking for. It also helps that they are reasonable and one of the quickest shippers i have ever experienced as far as purchasing parts. Good luck!
-Tony
Old 04-15-2005, 08:52 PM
blue_lateral's Avatar
Heres some better pics of the vhf knob
jc
Old 04-16-2005, 03:18 AM
Tim's Avatar
Tim Tim is offline
Polaraman:
I knew that knob was familiar but, I don't have the exact one. I do have a couple with the same handle form but not the correct skirt. Let me know if you want either or both to try and make work.
Tim
Old 04-16-2005, 08:37 AM
polaraman's Avatar
<--1956 300B
Tim,
I will take them both. I will Pm you my address later. I am off TV huntin!
polaraman
