Old 05-30-2005, 12:57 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
I think this particular set was discussed here on AK a couple years back. Not quite sure what to use in the search field to locate the thread.
Charlie Trahan
Old 05-30-2005, 10:29 AM
If you want ot go back to the New York 64-65 fair, here are some links:
an absolutely huge site covering New York 64-65:
http://www.nywf64.com/
including my writeup and pix of the RCA exhibit
http://www.nywf64.com/rca01.shtml
a discussion forum covering mainly New York (64-65 and 1939), plus other fairs, with some of the most expert people on the subject:
http://www.peacethroughunderstanding.org/
Old 05-30-2005, 10:31 AM
Old 05-30-2005, 03:05 PM
frenchy frenchy is offline
Frenchy
Originally Posted by andy
This is slightly off topic, but shows that color displays that use a B/W CRT are still around. This JVC professional monitor uses an LCD as sort of a solid state color wheel.
Hmm if you look at their 1st catalog for this set there, it shows the b/w monitor, then the 3 color filters stacked on top of it, with the 2 lcd shutters layered between the filters. I don't get how this works - the filters are all stacked so the light has to go thru ALL of them? How the heck do you just get red, or just blue? (with a wheel, it only has to go thru one color at a time). How do the shutters work, obviously they can't shut light off completely, or just the first shutter would result in no picture. Are the shutters divided into pixels, or is it just a solid pane shutter that goes from clear to black? Can anybody explain how this thing works? thanks...Frenchy
Old 05-30-2005, 04:56 PM
Tim's Avatar
Tim Tim is offline
I remember seeing this set before as well. There was discussion on this, or a similar set, back in 2001 on the ARF site. The photos are gone now though. http://antiqueradios.com/forums/Forum6/HTML/000068.html
Tim
Old 05-30-2005, 06:15 PM
dewickt's Avatar
dewickt dewickt is offline
Will fix about Anything
Have seen many of the 3 LCD projectors (by Sharp) that use an LCD light valve for each color and prisms to combine the RGB to one beam. The light valve is dark untill a pixel or pixels are excited then it goes clear to let light thru. They use an arc lamp as the light source.
Terry WB4NHB
DeWick Repairs (retired)
www.mcintoshaudio.com
Old 05-30-2005, 09:01 PM
I suspect the 3 color filters are not plain red,green blue, but are polarized somehow - one LCD then switches transmissions between red and cyan, and the other between blue and yellow.
Red+yellow --> red
cyan+yellow--> green
cyan+blue--> blue
red+blue - not useful - black or nearly so
Old 05-30-2005, 09:21 PM
Old 05-31-2005, 12:36 AM
Frenchy
Red+yellow --> red
cyan+blue--> blue
But how can you get only cyan+yellow, if red is inline with the other two filters? Dito on the other combinations. Their graphic shows all three filters stacked on top one another in front of the crt face.
Old 05-31-2005, 10:12 AM
You are correct that if there are stacked filter sheets that always look red, green, and blue, then no light can be transmitted! So, obviously, the drawing and explanation must be confused and misleading. You can find an example of the kind of LCD shutters I described here:
http://www.colorlink.com/tecpage/tecpage.html
different possible arrangements:
http://www.colorlink.com/tecpage/pdf...olorswitch.pdf
complementary color version I described:
http://www.colorlink.com/tecpage/pdf...0colorquad.pdf
more:
http://www.colorlink.com/tecpage/pdfs/pw97.pdf
what I described:
http://www.colorlink.com/tecpage/pdfs/pw96.pdf
Old 05-31-2005, 10:59 PM
Frenchy
The last tech paper in your list has a graphic that looks similar to theirs, two shutters sandwiched between color layers.... sort of.
Old 06-08-2005, 12:48 PM
trinescope trinescope is offline
I'm the one who posted about this set a few years back here and on antiqueradios.com. I still have it and it is in working condition, but is missing the knobs, the two woodgrain escutcheons, and the red Mitsubishi light-up logo below the channel selector knob. The picture shown at the top of the thread is a smaller version of the set I have; I guess the "viewing window" was widened a bit soone could view the set slightly off axis. This set uses series-string vacuum tubes; the chassis sits vertically on the right-hand side. The three CRTs have red, green, and blue phosphors; no color filters are used. Like someone just said, it produces a bright picture, and I'll add to that a Technicolor-like vividness to the color. The downside is the small (5-6") picture; but Mitsubishi provided a plastic Fresnel lens to mount in front of the window as a magnifier. The set appears to have been made in 1964 since many parts in the set have a 1964 date code. I doubt these were ever sold in the US in great number as the tricolor CRTs had already existed for years, and the trinescope, at least to me, appears to be a bit Rube Goldberg-ish in comparison.
Old 04-06-2007, 01:01 PM
Mitsubishi trinescope flyer
I just picked up the flyer handed out at the NYWF for the Mitsu trinescope.
Old 04-06-2007, 01:36 PM
Old 04-06-2007, 01:44 PM
jedo1507r's Avatar
jedo1507r jedo1507r is offline
Dang! Interesting set, but it does - in a way look like a furnace.
