Old 10-20-2006, 11:38 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Well, I think I gave this thing my best shot. If anyone out there is considering buying a Ramsey TV-6C, I'd be inclined to say, "Don't waste your money".
The source of the major problems seems to center around Q5, the 2N3866 output transistor. The power-supply is a rock-solid regulated 9V with no ripple whatsoever, which is great. The audio and video amplifiers do their job perfectly, and the two are mixed appropriately, which is also great. The local oscillator, tuneable to channels 3-5, puts out a very nice sine wave at the proper frequency of choice (mine being 62-ish MHz, or channel 3), which is great too. 90% of the "squirreliness" appears to be at the output stage. The Q5 transistor is a brass button type, presumably for shielding and heat dissipation. It does neither well. The collecter is connected to the case, but in this circuit the emitter is grounded, so the case is free to collect stray radiation and rebroadcast it in something of a feedback situation. It also runs uncomfortably hot, and its characteristics change with temperature, which leads to drifting and inconsistent performance. On no video/audio input, it also doesn't reproduce the oscillator's sine wave all that well (ramps up faster than it ramps down, a "wiggle" halfway down). This leads to harmonics, such that when tuned to channel 3, channel 8 also has the signal, almost as strong. And there's a mess on channels 2 and 4 and even 5, so there's no hope of buying several units and broadcasting all your favorites on more than one frequency.
If you moisten a finger and place it on top of Q5 (and let the pain subside as you bring its temperature down), then tune the various trimmers for best picture, you get a very stable situation. Take your finger off and all hell breaks loose. Obviously a guy can't use it that way. Applying your finger does two things, it sinks all the heat, and it damps out all the transients floating around the transistor's case. There's an immediate catastrophe when you remove your finger, which worsens over the 60 seconds that the transistor takes to heat back up. Replacing your finger removes the worst of it, then after 10 or 20 seconds, as the temperature subsides, you get back to "tuned". Pretty unacceptable.
I tried cold-water-pipe grounding the case, no improvement. Couldn't think of much else to try there, outside of digging up a cadaver and permanently mounting its finger to Q5.
I removed the onboard antenna and soldered a 25-foot piece of 75-ohm coax in its place, then placed the (removed) antenna at the other end of the coax, across the basement, and tuned the trimmers to that configuration (after Q5 heatup). This actually improved things almost to the point of satisfaction. I guess operating Q5 an inch away from the antenna is the TV6C's biggest flaw, and perhaps the reason for an external-antenna jack on back.
However there's one other flaw, I can't trace down nor explain, in that there's a slight, sudden increase in amplitude at the antenna, then a slight decrease, at a specific period (60 Hz?) that results in a series of lighter vs. darker blocks of picture, about half the picture height each, which slowly "walk" up the picture as you're watching your program. It's noticeable-to-annoying, and no amount of tuning removes it completely. Like I said, the regulated 9V is rock solid, but I don't know, maybe the regulator is radiating something?
It's also disturbing that the video and sound are both xmitted at the tuned frequency (they should be separated by 4-5 Mhz). They seem to count on "bleed" to get both to the TV set. I'm guessing that's why it's so hard to get clean sound AND clean picture at the same time, although rather easy to get one or the other.
So that said, I'm s__tcanning the project. The guys at Ramsey didn't do their homework.
Save your money. Not worth the price of admission.
-k
Old 10-21-2006, 12:02 AM
Thumbs down
Ramsey kits were never much good. Your best bet is to salvage a TV modulator module from a dead VCR. You may need to build a small power amp if you want it to feed all the TVs in the house over the air. The Ramsey circuit you posted might do (but will need some mods). I'm a little hazy here with VHF linear "power" amps, but I think an emitter resistor of around 20 ohms, and a radio frequency choke from the collector to B+, and remove whatever was used to inject the video and audio into the collector.
Old 10-21-2006, 01:19 AM
Q2 and Q1 form a sort of video op-amp. The video gain of this amplifier is the ratio of R8 (4.7k) divided by the video gain pot value (R3). You can see that if R3 is set to half way (500 ohms) the gain is about 10 times, which means you are already trying to get 10 volts of video out of Q1, which only has a 9 volt supply! So - the circuit is cheapened by not having another resistor in series with R3 to limit its minimum value. Starting point for R3 setting should be at max resistance, and only adjust to a lower value if you are not getting enough contrast.
R7 (BIAS) should NOT be adjusted for all black video conditions as the article states - its real purpose is to prevent getting zero-carrier clipping on whites. It has a similar problem to R3, in that it should be limited so you couldn't go to zero resistance. Always start with this pot at max resistance, and only adjust it as needed to prevent white clipping and sound buzz. Note that at zero resistance it shorts out the input to Q2 and the feedback from Q1 - very bad for operation.
Regarding the RF output transistor, I can't guess immediately from the diagram what the dissipation is. However, the output transistors should be driven class C by the RF oscillator, while the video modulates the collector voltage. This circuit is expected to generate harmonics, much of which are supposed to be filtered out by C12, L1, and C13. Scoping the collector directly will show harmonics to some degree even though c12 is right there. There should be less harmonics at the output on C13.
Regarding the sound, Q3 is a simple frequency-modulated oscillator, tuned to 4.5 Mhz nominal frequency by T1. The 4.5 MHz sound carrier is mixed with the video by R9 (10k ohm), so it is at about a 10% level compared to the video that comes in through R3. So, if you scope the emitter of Q1, you should see video of several volts (with sync positive, since Q2 is inverting), with 4.5 Mhz "fuzz" of about one-tenth the video amplitude riding on it. This combination is what modulates the collectors of the output transistor(s). (The capacitance of your scope probe may cause some distortion and amplitude reduction of the 4.5 mhz).
By the way, L3 (2.2 microhenry) is meant to prevent the RF from getting back into the video/audio circuit. How good it is in the real world, I don't know, so you might see some RF messing up your scope readings here too.
Another caution is on tuning the channel frequency. This circuit modulates double sideband, and you need to be careful that you have not accidentally tuned it to the next higher channel (channel 4 while trying to receive on channel 3, for example). You may get a recognizable picture but not a good one from receiving the lower sideband this way.
Old 10-21-2006, 12:00 PM
kbmuri's Avatar
I went back and looked at that web article, and obviously it's an earlier version of the transmitter. I was a little confused when you said "output transistors" (plural), and "class C operation". My kit has only one output transistor, the hot-runner I described earlier. Schematic attached. I wonder if the push-pull version worked better, and why the change (performance or cost?).
I probably confused some people talking about the 9V power regulator too. Something apparently they added later, as it's not in the web article either. They recommend a 12-15V supply (mine is 13.8V), the 7808 VR1 flattens it very nicely to 9V.
The oscillator and audio/video amps look unchanged. I guess I don't follow how the audio oscillator at 4.5 Mhz adds in, but I guess that's the signal that affects the shape of the sine wave at Q5's output, so I guess that's ok and the harmonics are expected. I don't think they're filtered well though, as like I said, tuning channel 3 also pretty clearly tunes channel 8 (the 3X harmonic).
Anyway, hope this schematic clears up what I was describing. I still can't see the people at Ramsey being proud of this product. Maybe the TV-7 or 8 or 9 will get it right someday... Not there yet, IMHO.
Old 10-21-2006, 01:41 PM
Eunomians's Avatar
Eunomians Eunomians is offline
Diggin' 4 LP's Worldwide
I am glad to read this post as I had high hopes for the Ramsey Unit.
I've also thought about one of their FM transmitter kits. Maybe I'll stay away.
Sansui 9090
AR-XA
Nakamichi 500
ADC CD-100X
Tascam CD-RW4U
Hughes AK-100
DBX SNR-1, 3BX, 120X-DS
KLH TNE7000A
BBE 1002
AR 3a, 4x, 6, 7
KLH Model 6
Minimus 7, 7W
Boston A-40
Niles SVC-2
AR SRC
Old 10-21-2006, 03:26 PM
Old 10-21-2006, 04:40 PM
Chad Hauris's Avatar
I use a Channel Master amplifier from a school to amplify the VCR CH. 3 output before it goes to the TV's through splitters...this can serve about as many TV's as you can hook up to it with no loss of signal quality. A Radio Shack VHF amplifier will supply 6 sets or so. Without using an amp the splitters seem to attenuate the signal too much if you use more than one.
Chad Hauris
Old 10-21-2006, 11:08 PM
peverett peverett is offline
The problem that I have is that I would like to view non-broadcast channels (and prepare for 2009) to my workshop which is behind my house. It has no cable. Radio shack has some GHZ transmitters that work well room to room (no need to run cable), but my workshop is at the limit of their range. Depending on the weather, the Radio shack unit may have a decent picture or not, the sound is usable, but never very good.
The Ramsy unit that I have will broadcast a picture that far to a 1955 B&W Admiral that I just restored. However, the sound is non present and the problems mentioned by kburi upon warmup are all present.
As mentioned before, I have not yet had a change to work on adjusting it.
Old 10-22-2006, 12:44 PM
kbmuri's Avatar
This will work!
http://audiokarma.org/forums/showthr...224#post857224
Seriously, the reason I'm interested in this hobby is to preserve a "golden age" of TV (1950 +/-). Cable TV was sort of around back then (Zenith "phonevision" for example), but it wasn't really mainstream until around 1975. Then came VCRs, IR wireless remote controls, satellite dishes, MTV and Nick-at-Nite... Not really desireable to run them on a 10-inch roundie in mono Lo-Fi. These old TVs were made for The Honeymooners and Lucy. I put a 2005 el-cheapo VCR on top of my Magnavox briefly, and it looked so out-of-place that I took it back off in disgust.
The least obtrusive "modern" solution I think is the Radio-Shack 2.4 GHz transmitter/receiver pair, hiding the receiver inside the TV cabinet. But that still places the burden of "tuning" on the VCR or Satellite box driving the transmitter, and reduces the vintage TV to status of "monitor". Never using the tuner again. And the cost of putting a separate 2.4G receiver in each TV set.
There are no VHF stations where I live. The only answer for me is to broadcast VHF myself. Sad the Ramsey units suck so bad, but it should still be technically possible to set up somewhere between 1 and 12 "repeaters" of your favorite 1 to 12 TV channels and hide it all in a central closet or basement of the house, and then use ALL your vintage sets as intended without modifying them. My '50 Philco, '51 Zenith, and '64 Zenith sets have VHF antennas built into the cabinets -- no external wires whatsoever (except the power cord of course). As it should be. Even wiring cable to them sort of defeats the purpose of commemorating 1950.
I'm still working on a solution...
- k
Old 10-22-2006, 05:48 PM
The Radio Shack units are what I use in my house. These will drive more than one set. I am using one receiver to drive three 1953 Hoffman sets without any problems (I am using a passive splitter). I would be driving a fourth set, an early Admiral, but the signal overloads the AGC on this set. The Hoffmans have switches that allow changes in TV gain for different signal strengths. This is why they do not have overload problems.
I have purchase an adjustable annenuator (also from Radio Shack) to put in series with the incoming signal on the Admiral.
Old 10-22-2006, 05:49 PM
Originally Posted by kbmuri
...I wonder if the push-pull version worked better, and why the change (performance or cost?)....
Q5 and Q6 are just in parallel - not push-pull.
Old 10-22-2006, 08:34 PM
kbmuri's Avatar
Agreed. I didn't look at the older-version schematic very closely. Paralleling transistors seems strange to me. Two transistors paired together in the audio world usually means a push-pull circuit. At a glance, the two in the early Ramsey unit looked similar. Just sharing the power burden?
"Class C" is explained here if anybody else is curious.
http://en.wikipedia.org/wiki/Electro...lifier#Class_C
I'm not a EE. Never claimed to be. Just handy with a soldering gun sometimes.
Old 10-23-2006, 02:48 PM
Post
Seeing the entire diagram I can make better sense of it now. Q3 looks to be an oscillator at 4.5Mhz, and its internal PN junctions' capacitence is being varied by the audio signal voltage. That creates an FM signal. General Electric used a scheme like this to do Automatic Frequency Control in their solid state AM/FM radios they made around 1969. Using voltage to shift the frequency. I'd adjust L1 after I succeed in getting a video signal seen on the TV set. Adjust L1 to get the sound carrier demodulated properly by the TV sound circuits. Be sure the audio input level isn't too high.
The RF power amp is being "plate modulated" to modulate the video and FM subcarrier onto the TV channel carrier. Some older AM radio station transmitters used this method. Video is amplitude modulated onto the TV channel. Real TV stations also partly filter out most of the lower sideband, but VCRs and other such devices don't bother as they are usually in closed circuit environments (not radiated into the "air").
You could connect a TV coax cable (the F connector type) to where the 75 ohm resistor R12 is, and remove that resistor. The 75 ohm termination at the far end would be a 75 to 300 ohm balun in turn connected to a TV set.
What is likely happening is that some of the output RF signal is finding a path thru the power supply rectifier diodes. As the rectifier diodes turn on and off at the powerline frequency, this RF path also is switched at the powerline rate. One solution is to insert choke coils in both power supply wires from the power supply. A few milliHenrys should do. You can usually find a suitable coil used in the power feed of a dead computer monitor or PC power supply. Those usually have a pair of windings on the same core, one for each power supply wire (the + source and - return aka ground).
This kit's schematic looks to be adequate for the job. Not great, but it should work reasonably well. Things like the power supply chokes should have been added to make success more likely.
