Old 10-13-2006, 12:31 PM
dr.ido's Avatar
dr.ido dr.ido is offline
Originally Posted by daro
I also remember the practice was used in some Australian designs as well, The early PYE W101 & W201's mounted the 2 6N3 rectifiers on the power TX & I think there was a couple of others as well.
I stripped a lot of old tube B&W sets as a kid (I wish I had some of those sets now, but don't we all) including a lot of Pye's and I've never seen transformer mounted rectifiers.
I wonder if those sets were more common outside of Victoria for some reason.
Old 10-13-2006, 06:03 PM
daro's Avatar
daro daro is offline
W101 & W201's were made in around 1956-1958 by Pye-Technico in Sydney, I had an W201C, The C was as in console with an 21" CRT.
The 2 6N3 rectifiers were mounted on a bracket on the power transformer along with the voltage adjustment switch, The set also had an removable power cord similar to the interlocks found on most US sets of that vintage where you had to remove the power cord before you could take the back off the set to service the chassis.
Old 10-26-2006, 02:43 AM
Glass Bulb Bob
Guest
Posts: n/a
Yep I just aquired a Pye W201 and it does indeed have the 6n3 rectifiers on the transformer.
I was hoping you guys could help me out with some further info, I have documented all the tubes in the set but there is one I cannot identify due to the fact that the silkscreening has come off. Does any one know where I can find a scematic for this old bugger?
Old 10-26-2006, 04:08 AM
blue_lateral's Avatar
Nice set! Have you tried over here?
http://www.vintage-radio.net/forum/index.php
I have seen the name "Pye" come up a lot in those forums.
Oh, and welcome to AK!
Old 10-26-2006, 06:31 AM
Glass Bulb Bob
Guest
Posts: n/a
Thanks for the link, and the welcome.
There is a whole heap of stuff to go through there!
I'm waiting on a 6al3 tube to finish of the power supply and than I can fire this puppy up to see what needs some love'n. Hopefully it fires right up without a hassel, but I'll keep searching for that schematic, sooner or later I'm gonna need it.
