Old 08-13-2007, 02:08 PM
El Predicta El Predicta is offline
If you don't mind paying $80 each + shipping, there's a former employee of Video Display Co. (now relocated) that might help. He's in Dallas and did a couple that turned out good for me last winter.
Larry
Old 08-13-2007, 02:16 PM
I would like to hear results of any solvent experiments, too. The heat method seems scary/dangerous, and I don't have a lot of Kevlar suits, space helmets, or other protective clothing lying around the place :-)
Dipping the whole thing in a kiddle pool filled with -- whatever -- for a few days sounds much more relaxing.
Old 08-13-2007, 08:01 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
I was thinking, what about using your standard basement stationary tub filled with hot water? I imagine that warm water would loosen the PVA much faster.
Old 08-14-2007, 12:10 PM
kx250rider's Avatar
REAL TVs have TUBES!
Larry
Does he have an oven and facilities to rebuild tubes at home, or just the cataract repair? I'll be in Dallas in the next few weeks, and I might pay him a visit
Charles
Old 08-14-2007, 01:50 PM
polaraman's Avatar
<--1956 300B
Video Display moved their Dallas CRT operations to Pennsylvania and is no longer servicing CRTs there. Charlie started a thread about it here on Ak. They were rebuilding 21 inch roundies for $150. Not anymore!
Is this person rebuilding CRTs or just servicing the faceplate?
polaraman
On the Bench: Master's Degree Thesis!
Old 08-14-2007, 07:04 PM
Just the faceplates.
Larry
Old 08-15-2007, 08:43 AM
Success!
After work yesterday I checked things out-it had been 48 hours. There really was no visible change over the last day. The pva that was exposed had turned a fatty white but there was no sign of delamination. I decided it was time for some gentle coaxing. I grabbed a handful of popsicle sticks and broke them in half. I started inserting them in the corners. I found that the top of the crt had slightly thicker pva than the bottom and thus I could insert them better there. The pva in those areas had softened, it seemed. Upon insert there were some bubbles in the area of insertion. I layed it back down in the water for another couple hours.
When I returned I spent a few minutes prodding the top corners with additional sticks. One corner in particular was responsive. In short order I had the situation shown in the first picture, an area roughly the size of my hand that had popped loose. I was being gentle. I know the crt faceplate is very thick and that did not concern me. The worry is that I have heard from several others about safety glasses that broke. Anyway, the other corners were not as responsive. I layed the glass back down for a few more hours.
At 10pm I went out with my flashlight and checked again. (I knew I couldn't stand waiting all night) After another few minutes of gentle prodding fully 1/4 of the face had popped and the other top corner was starting to loosen. I added additional sticks all around and went inside for about another hour.
When I returned the entire top half-more like the top three fifths-was delaminated. With the crt layed down I prodded and tugged and was able to feel the glass let go. It just took some gentle tugging to break the last bond-it was loose but rubbery.
I took these photos this morning. I left them in the pool for today because I didn't have time to work on it and the additional time under water will make it easier to clean the glass. I plan on trying double sided tape on this one. This is a spare crt that I just had in storage. It's not real strong on the tester but acceptable. It next goes back in the attic.
Is water the magic bullet? It's not perfect but, yes, it does work. I suspect eventually the pva would let loose entirely on its own without any prodding but what I did was gentle-not even as harsh as when I did one with a heat gun. If you have someplace where it can sit out of the weather you could leave it for quite a long time. The crt will float, sinking just enough to keep the faceplate underwater. The biggest advantage over a harsh solvent is that when you are done you can just drain it, and of course there are not the hazards involved with flammability. It may be that things could be added to the water to expedite the process-maybe lots of dish detergent? One issue with a solvent is that I doubt the vinyl of a pool like this would hold up to it. Finding a metal or poly container large enough might not be easy.
Between now and fall I am going to be working on a set with a crt that has the "gray" cataracts. I will try it in the pool-I suspect it will be quicker to respond if anything. I will report the results at that time.
Old 08-15-2007, 12:44 PM
fsjonsey's Avatar
Thats great news! I have the exact same tube that I've been wanting to do since I got the TV. It has the yellow cataracts pretty bad around the top edges. This Zenith is my first tube color set, and its in one of the most hideous colonial cabinets I've ever seen, plastic woodwork and all. Beggers cant be choosers i guess? I've been thinking about having someone build a custom cabinet for it, seeing that the tube tests strong on all guns, and the chassis is in good original condition. Time to go to walmart for a baby pool, and maybe an aquarium heater to keep the water warm.
Old 08-19-2007, 10:34 AM
captainmoody's Avatar
captainmoody captainmoody is offline
Great idea Bryan! Wow! That worked so well, I am now going to try it on one of my tubes. I always stayed away from the green pva problem ones due to the difficulty. Thanks to you, it looks like we have another way to keep them going!
Old 08-20-2007, 08:21 AM
Yes, Captain, I figured I was just stuck with green halos because I really didn't want to try the hotwire trick. I'll add a couple observations: the real progress came when water started getting under the glass. Once one corner opened up I think the water was able to seep down. The pva is tenacious. It took some time to remove it all from the glass-with some of it I ended up taking a brillo pad to get it clean. One of the things that happens here is that the pva absorbs water. Even after a couple days underwater the crt face looked just like it did when I started. But by the time the safety glass came off the adhesive was white in color. I piled up the stuff and once it dried it was again yellowish/clear. It has a foul smell. I would warn anyone who tries this to take your time, don't force things. And keep your hand away from that ultor connection while you're moving that crt around!
I've posted a pic of the finished product.
Old 08-20-2007, 11:55 AM
fsjonsey's Avatar
Wow! That looks like a brand new tube! What method did you use to remount the glass? A bead of silicone or double sided tape?
Old 08-21-2007, 10:01 AM
This time I tried double-sided tape. (first time) Overall I liked it, though with one layer of tape it didn't fully touch the tape. It was enough, though, so I left it. A second layer or some thicker tape would be better but I wouldn't want to go too thick with these etched safety glasses because you could lose too much picture clarity by being too far away.
Old 08-21-2007, 12:24 PM
kx250rider's Avatar
Nice work!!!!
I'm impressed with how original it looks. What kind of double-sided tape was that? I thought about using the foam house window insulation tape, which comes in various widths and thicknesses.
Charles
Old 08-21-2007, 02:33 PM
I used some automotive tape as used to hold moldings on cars. Some brands are gray, others white. The stuff I have is black so it doesn't show up under the glass. There are various widths. This was 1/2". Kind of expensive, though, at $25/roll. Good stuff-if the conditions are right it has a death-grip. This stuff is fairly thin, compared to some household weatherstripping tape that can be on the thick side. Just using the sealant works fine, too, just takes a few more minutes. If you make continuous corners with the tape it can kinda bunch up. I'm not sure if that would be easier or harder with a round tube. Another idea would be to use the old-style butyl rubber like what was once used to hold auto windshields in. It stays gummy and is black. I have seen it in tiny ribbons that would work well, probably 1/8" thick would do. Windshields use nothing less than 1/4" which I think would be too heavy.
Old 08-21-2007, 03:29 PM
