Old 01-19-2007, 02:47 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
I drove up to see the set. The 15GP22 is under vacuum. The set was used by a CBS technical exec. Good, original documentation. It was in service to at least 1962. Clean chassis. No rust I could see.
Old 01-19-2007, 04:14 PM
WA3WLJ's Avatar
WA3WLJ WA3WLJ is offline
How Hard to Get it Runnin' Pete?
How hard would it be to get running ,Pete?
Old 01-19-2007, 05:27 PM
Nothing seems to be missing. Probably just your typical 52-year-old vintage color challenge. The unknown lies ahead...
Old 01-19-2007, 07:07 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
Originally Posted by John Folsom
His description is a bit inacurate. This is a CBS model RX-90, mand in the spring of 1954. The CRT has likely been changed, as the sets originally had 15HP22s in them (the CBS Hytorn variation of a 15GP22). But this is a great set, with full bandwidth I/Q demodulation, and circuitry very similar the the better known production CBS model 205 set.
Guess as I have one already, I won't chase after this one. Godd luck, bidders!
Does your set work John?
[IMG]
Old 01-19-2007, 08:08 PM
WA3WLJ's Avatar
LESS THAN an Hour to Go
And , at OVER THREE ; ALMOST FOUR( $ 4000 )Thousand Dollars !!!
Old 01-19-2007, 08:57 PM
polaraman's Avatar
<--1956 300B
Bids going up $100 each time. Somebody is going to snipe this set at the last second. It will not be me! Are we going to see $10k on this one?? Less than 5 min left!!!
Pete,
This set was under you nose! Did you know it was there?
polaraman
On the Bench: Master's Degree Thesis!
Old 01-19-2007, 09:05 PM
polaraman's Avatar
<--1956 300B
The set is off to Italy!!!!!
polaraman
Old 01-19-2007, 09:41 PM
Originally Posted by polaraman
Pete, This set was under you nose! Did you know it was there? polaraman
I did. In fact, here's me with the set at Saddle River, NJ earlier today. I mean, why so many $$? It's missing its HV cage cover.
Old 01-19-2007, 10:03 PM
polaraman's Avatar
<--1956 300B
I would have drooled all over it!!! Glad I was not there.
See you at the Tv convention!!!
polaraman
Old 01-19-2007, 10:15 PM
John Folsom's Avatar
Cbs Rx 90
HiOLDTVMAN. Ye, my RX-90 has been restored to good working order.
You can see more photos at:
http://bbs.macmad.org/~jfolsom/
John Folsom
