Old 09-12-2006, 09:34 AM
Marlin Mackley Marlin Mackley is offline
Originally Posted by David Roper
When I think mechanical TV, I think of, like, Western Visionettes.
That fits better with the premise of the Early Black & White forum...well...black & dull orange.
Agreed. Mechanical TV once had its own Forum division with its own threads, which I moderated, but disappeared a couple years ago, presumably from lack of activity. The other day I found I could access this thread of taht Forum through my personal AK account page and tried a post to see what happened, and where it showed up.
Marlin
Marlin H. Mackley
www.studio4-17.com
Old 09-12-2006, 09:50 PM
cbenham's Avatar
cbenham cbenham is offline
Black & Dull Orange
[QUOTE=David Roper]When I think mechanical TV, I think of, like, Western Visionettes. That fits better with the premise of the Early Black & White forum...well...black & dull orange.
I watched a program on a Western visionette a friend in CT restored. 45 scan lines, three 15 line fields. I was allowed to 'take over the helm' and steer the wheel.
I'm getting more interested in mechanical TV and may try to build one from the parts made by Peter Yancer. I watched TV on his 'Mirror Screw' receivers he showed at the Early Television Foundation Convention last April. Just amazing stuff.
Old 09-12-2006, 11:00 PM
cbenham's Avatar
Eidephor, Talaria and Baird
"Gretag manufactured a modern version HDTV capable based on the color dot sequential system replacing the original CBS field sequential method. Another system that owes much to Ediphor was the GE Talaria system." Tom[/QUOTE]
I got to play with a Talaria about 1979, and a year or so later saw a pair of
Eidephors set up at the NAB convention to produce an 8:3 image about 40 feet wide. They needed Cinerama 'giggolos' to blur the seam of the pictures together.
Projectors have come a long way since the live J. L. Baird mechanical color TV demonstration at the Domintion theater, London, to a surprised audience of 3000 on Feb. 4, 1938.
I wonder what that system might have sounded like when it was operating?
Old 09-13-2006, 09:30 AM
pronostalgia
Guest
Posts: n/a
Here are pix of my Western Visionette and my Echophone 41. Echophone was owned by Western Television at the time the 41 was made [1933]
Old 09-13-2006, 08:54 PM
[QUOTE=cbenham]
I can recommend it highly. It's a fun project, and the scanning discs Peter supplies are excellent, giving great pictures once you add your own motor and electronics. You can get an inexpensive video source from a CD player and the CDs offered by the narrow band TV association. And you can later consider getting a scan converter (more expensive) to display NTSC sources; or build a live camera (more difficult than the receiver, however).
Old 09-14-2006, 01:32 PM
doug621ts doug621ts is offline
Wow! A couple of great sets you have there! Are they complete and operational? There cant be many of those Echophones around!
Old 09-15-2006, 10:38 AM
pronostalgia
Guest
Posts: n/a
The Visionette is complete and working using Darryl Houck's converter that converts NTSC to the 45 line triple interlace format. I haven't started on the Echophone yet but hope to get it working,too.
Old 06-25-2007, 06:09 PM
Stafjohn's Avatar
Stafjohn Stafjohn is offline
Here is another Western Model 41 that is owned by my father-inlaw. I was told that the one my father inlaw has was the fifth one known of according to Steve McVoy. Not as good as shape as Pronostalgia's but I hope to restore it someday.
MX110, MC225, University Dual 12's,
Sanui 517, University Medallion XII's
Old 06-25-2007, 07:55 PM
wajobu's Avatar
wajobu wajobu is offline
Near and Far Horizons
Fascinating!
Yamaha, Manley, ADS, McIntosh, Rega, B&O & Victor Talking Machine
"...As worrying is interest paid on trouble, long before it's due..." - Steve Hackett - "Serpentine Song"
Old 06-25-2007, 08:20 PM
David Roper's Avatar
console lover
Yes, but also saddening in that "pronostalgia" is the AK handle of the late Dave Johnson. I tend to doubt he ever got to restore the Echophone.
tvontheporch.com
Old 07-07-2007, 12:39 PM
Gianni's Avatar
Gianni Gianni is offline
Slave to a blue dog
Thumbs up
Originally Posted by cbenham View Post
About 10 years ago I wanted to build a color wheel TV. I had pieces of an old Col-R-Tel unit but not enough to make a system. I also wanted to make something that would look really good with lots of resolution and less flicker than the Col-R-Tel, so I have worked on this project off and on, revising and improving it to the point where it now runs 640 X 480 @ 90 progressive frames per second [30 RBG color pictures per second] and has subjectively about the same amount of flicker as a PAL TV set. It is still a work in progress and I would really like to increase the vertical rate to 120 or 144 or maybe 180 frames per second. This gets difficult, but not for the reasons you might first think. It's not the wheel or the motor or the video, it's the monitor.
I can't find a nine inch monitor that will operate at this high a display rate.
I can spin the wheel fast enough and make a video signal that fast but can't find a 9 inch CRT monitor that will diosplay it.
I will probably have to build another set with a larger PC color monitor [with it's RGB inputs all tied together to make a monochrome picture] but that also means building a large 36 inch diameter color wheel for it as well. That will be more fun anyway.
Attached is a photo of the present 9 inch wheel set from the top rear.
Cliff
Beautiful work!
Have you any shots from your tv?
Flicker from a PAL TV is good for me, pheraps because i don't know the 60 Hz flicker.
Do you know well PAL's performances?
And finally, in your opinion, a wheel-based tv set can display a decent PAL picture?
Thank you.
<< Hi Gianni!
By the way, no need to apologize for your English, you speak 3 languages!
John Folsom >>
Old 11-01-2010, 04:08 PM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
As I was doing my usual searches for TVs on the internet I came across this EchoPhone Model 41 which sold at auction in 2009 for $3000
http://www.iowa-antique-radio-club.c...HSSummer09.pdf
Old 11-01-2010, 04:59 PM
That would be a sweet find!
Marlin H. Mackley
www.studio4-17.com
