Old 07-18-2016, 08:29 PM
Office space
Clockwork Orange
Classic Bloopers
Old 07-18-2016, 09:26 PM
truetone36's Avatar
electronics packrat
O Brother, Where Art Thou?
Almost Famous
Forrest Gump
Ray
Old 07-22-2016, 04:03 AM
Dude111 Dude111 is offline
Analogue is Awesome
Originally Posted by Electronic M
Office space
Excellent!!
Which do ya think is better buddy?
Office space or 9 to 5??
Old 07-22-2016, 06:31 AM
Never seen the latter, so I can't compare them.
Old 07-22-2016, 09:20 PM
Analogue is Awesome
Ah man!!
Old 08-24-2016, 08:24 AM
pac.attack76's Avatar
Stuck in the past
Ive got 9 to 5 on CED but i dont have office space yet.
Genesis does what Nintendon't
Old 08-24-2016, 09:51 AM
On a side note, the SVDP, I usually haunt has some CED's, Sound of Music, etc. One of the other regulars, who knows that I'm into vintage electronics asked me about them. I replied that was one of RCA's real losers. They're not Laser-read, but uses a stylus, like an LP record. If there was a machine there, I probably would have bought it and the discs.
BTW, what speed did they run on.
Old 08-24-2016, 10:23 AM
I believe it was 30 or 60 RPS. The vertical syncs can be seen on the disc as two bars pointing opposite directions from the spindle...Like some LDs.
If you had told me you wanted a player before the last ETF I'd have sold you one cheap.
Old 08-24-2016, 11:25 AM
Stuck in the past
RCA VideoDisc System, derived from various sources:
Disc System: CED 525/60Hz NTSC(US) 625/50Hz PAL(European)
Playback System: Mechanical tracking grooved capacitance
Playback Sensor: Diamond stylus with titanium electrode
Max Playback Time (in 1983) : 63 min/side (NTSC), 75 min/side (PAL)
Video Signal to Noise Ratio: >46dB (CCIR)
Chrominance Signal-to-Noise Ratio: >40dB
Chrominance Bandwidth: 0.5MHz
Luminance Bandwidth: 3.0MHz
Horizontal Resolution: 240-270 lines (magazine reviews)
Audio Signal-to-Noise Ratio: >50dB (USASI), 70 dB (with CX)
Audio Bandwidth: 15KHz
Stereo Separation at 1KHz: 26dB
Dynamic Range Mono: 50dB
Dynamic Range Stereo: 70dB
Audio FM Signal Deviation: +/- 50KHz
Audio Carrier, Mono: 716KHz
Audio Carrier, Additional Stereo: 905KHz
Disc Diameter: 12 inches
Disc material: PVC, carbon-doped
Rotation Rate: 450RPM (525/60Hz), 375RPM (625/50Hz)
Groove Density: 9,541 grooves/inch
Recorded Band: 2.83 inches @ 60 minutes recording
Still Frame Capability: 27,000 frames/side @ 60 minutes
Old 08-29-2016, 11:54 PM
Analogue is Awesome
Your lucky to have 1 PAC!!!
Old 08-30-2016, 08:07 AM
Stuck in the past
I couldnt believe it when i bought my first player. Since then, i found four more in an old storage and now have over 100 movies. I recently found a thrift with several discs at$1 each and bout him out.
Old 09-02-2016, 12:11 AM
Analogue is Awesome
G00d for you buddy!!!!!!
I wonder if sometime ya might feel like making a copy for me of a movie from VD to VHS? (If ya have the movie I mean)
Old 09-02-2016, 07:58 AM
Stuck in the past
Which movie?
Old 09-03-2016, 02:24 AM
Analogue is Awesome
Well there are a couple I would LOVE
ET - 1982 (Was this ever released on VD?? -- It must have been (The earliest VHS I can find of this is 1988 and that one was DIGITALLY RECORDED (There must be an earlier MCA VIDEOCASSETTE release (I havent found it though))))
The Goonies - 1985
The Terminator - 1984 (If its the right NTSC speed (The first VHS release is PAL (Even the NTSC one -- They messed up)))
Those are about the only ones I could possibly want from when VD was made
Thank you pac for seeing if ya have any of these
Old 09-03-2016, 10:49 AM
Stuck in the past
I don't have any of those. Definitely want the terminator. I'll see what I can find.
