Old 01-06-2022, 03:34 PM
Good you got that working.
Now before you go crazy trying to set linearity on the Zenith... do you have a known good somewhat modern TV you can hook the B&K to, something to verify it didn't get it's own linearity messed up during shipment? It does have linearity adjustments very similar to a TV. And don't mess with them unless you have a TV that you know is very near perfect picture. You can even use the B&K Video out to go into composite video in on a newer TV. Here again it doesn't need to be perfect, you just need a reference so you know what it normally looks like. Everything is relative.
Yes I have several newer CRT Sets all of them are color sets, one is a Zenith 9" Color TV from 1986, and then I have a Monkey Wards 5" Color TV from 1982, and then I have a 13" Magnavox Color TV from 1991, and then I have my GTE/Sylvania 25" Color TV from 1974 and all 4 of those TVs have darn near perfect linearity.
Old 01-06-2022, 03:53 PM
Kevin Kuehn's Avatar
Workin' Late Again
OK. After you get that squared away it would be great if you could provide us a picture of what you're currently looking at on the Bugs CRT. BTW did you actually check to see what you replaced the 60uf cathode bypass cap with on the video out tube? When you moved the ion trap, were you able to make the picture brighter, or was it best were it was previously?
Old 01-06-2022, 04:22 PM
When I moved the ion trap the screen would get brighter. The bypass cap for the 6CM7 tube was replaced with a 47 MFD cap with a 39 MFD cap in parallel to make 78 MFD, both caps are rated for over 100v.
The weird thing is that I actually had a really good picture on the TV going through the Tuner using my NES as a good stable video source and when I went to switch over to a converter box the picture went haywire and I wasn't able to get the tuner to lock in on the converter box signal, but yet it locked in rock solid with the NES.
What's up with that?
Old 01-06-2022, 04:51 PM
Workin' Late Again
78uf may possibility be too much. That tube needs to be biased "just right" in order to get vertical linearity in it's sweet spot, so that it interfaces well with the height and linearity controls. I have a 47uf in parallel with 22uf on mine which seems OK. Has something to do with were the tube amplifies relative to it's characteristics load line.
Lot's of folks have reported very strange things a happening with converter box's. One thing we can be sure of , they were never designed for compatibility with older than dirt TV's.
Old 01-07-2022, 08:47 AM
Well lets see here, I did previously have a 59 uF capacitor (a 20 and a 39 uF capacitor in parallel with each other) in place of the 60 uF capacitor but then you had said that the capacitor needed to be 60 or more so then that's when I upped it to the 39 and the 47 uF caps.
Should I go back to the 59 uF cap?
I wonder if the converter box issue has something to do with how sensitive the tuner and IF is to switchmode power supply noise? Because I know the converter box works fine with my Meck TV strangly enough but then it might be because that TV isn't overly sensitive to outside RF interference such as that put out by SMPS.
Old 01-07-2022, 10:27 AM
Workin' Late Again
Should I go back to the 59 uF cap?.
I honestly don't know for sure. I was just suggesting it on a hunch because I struggled to get the vert linearity straightened out on my own set. It's not a straight forward linear amplifier.
If your tuner is so sensitive it's possible your TV's AGC circuit isn't working correctly. You could try measuring the AGC DC control voltage at point D on the Sams schematic. It should be around positive 1.5v with no input signal, around -4.5v with a strong signal. As a reference I've measured mine using an older DVD/VHS player with an RF output. The key being you should see some kind of AGC voltage swing dependent on signal strength. If that's not happening you could try forcing point D negative by putting some negative DC voltage across that point and ground(positive goes to ground). Maybe a couple 1.5v batteries in series. Just remember that going more negative reduces the gain of the TV's front end. In the end you really shouldn't expect these old set's to operate reliably in a noisy RF environment, such as switch mode supplies in their near vicinity.
Old 01-07-2022, 12:25 PM
Here's what the TV looks like with my NES hooked up and running.
See picture below.
File Type: jpg Zenith Bugeye TV with NES hooked up.jpg (62.9 KB, 16 views)
Old 01-07-2022, 12:57 PM
Workin' Late Again
See picture below.
Excellent. Is that through the antenna input, and back to your 59uf cathode bypass?
Old 01-07-2022, 01:04 PM
Yes to both.
Old 01-07-2022, 04:00 PM
Yep the Bugeye is finally fixed for sure, and unfortunately the TV won't work with a converter box for sure, and it for sure has to do with the converter box's switchmode power supply because as soon as the converter box powers on you can hear and see the switchmode power supply oscillating through the TV's tuner.
I'll just have to use an RF Modulator to hook a VCR or DVD Player up to the TV and just use the TV to watch movies on.
Old 01-07-2022, 04:17 PM
It's possible if you feed the composite audio/video from the converter box to the VCR and let the VCR modulate it into RF that you'll be able to watch the converter box on the bugeye.
Old 01-07-2022, 05:33 PM
Workin' Late Again
What brand and model is the offending converter? Is the power supply internal or a wall wart?
Old 01-07-2022, 07:27 PM
I have 2 converter boxes, and both of them do the same thing, one of them is a "Zenith" model DTT901 and the other one is a "Magnavox" model TB110MW9 and both of them have a built in power supply (no wallwart.)
Although now I'm beginning to suspect something else. By any chance is the frequency at which channel 3 and 4 are running at on the NES RF modulator at a different frequency than the channel 3 and 4 on the RF modulator on the converter boxes?
I'm asking because I even tried a radio shack RF Modulator (of the variety that has RCA and S-Video inputs on the back so that you can make a TV without A/V inputs have A/V inputs) and not even the Radio Shack RF Modulator would work with this TV.
Any ideas?
Old 01-07-2022, 08:36 PM
Workin' Late Again
You should be able to set the RF output of the converter box to ch 3 or 4. Can you test that by plugging into one of your newer TV's?
Old 01-07-2022, 08:45 PM
They are both set to channel 3 as far as I know. The reason I asked about the frequencies of channel 3 and 4 on my NES vs my converter boxes is because I know that in Japan even though they used NTSC just like we did, their channel frequencies were slightly different than ours were especially on the lower VHF channels like 2-6, the reason I know about this is because I saw the video Shango did on a late 1960s Hitachi Console TV that was originally meant for the Japanese market and when he worked on it he had to use different channel settings to get stuff to come in correctly on it.
