Old 12-02-2025, 12:15 PM
The maggy in the new location, for now! :P
Nice!
Old 12-12-2025, 11:31 AM
http://suzaku.live-evil.org/maggy-solved.jpg
As I mentioned, I'm done with the set for now...
But it's still a bit too wide and linearity is off, as for width, S101 adjusts it by swapping in resistors on G2 of the HOT, what effect will raising or lowering the values of them have on width?
Someone also mentioned changing the 100 ohm cathode resistor to a lower value, but won't that also lower the HV as well?
Old 12-12-2025, 05:04 PM
Kevin Kuehn's Avatar
Workin' Late Again
You could experiment with a width sleeve. That consists of some thin brass shim stock wrapped one turn around the neck, so it just overlaps. If I recall correctly you get the most width with it removed, and gets less as you slide it into the yoke.
Old 12-18-2025, 05:27 PM
I got a new toy for Christmas!
http://suzaku.live-evil.org/20251218_170449.jpg
http://suzaku.live-evil.org/20251218_170532.jpg
That and a few others..
I won't be able to set it up till later.
Old 12-18-2025, 05:34 PM
If I knew where to get one! :P
Old 12-20-2025, 04:54 PM
Yet another new toy!
http://suzaku.live-evil.org/ezgif-618c4c9687f96e65.jpg
This one will need to be restored.
But the Transformer is good, and the 6E5 is strong!
Old 03-03-2026, 09:05 PM
http://suzaku.live-evil.org/ring-ring.jpg
RING Ring!
