Old 03-16-2012, 07:06 AM
Steve McVoy's Avatar
Here is an article from 1952 about RCA color. Nick, could this be the cabinet your chassis was in?
www.earlytelevision.org/color_tv_today.html
Old 03-16-2012, 09:36 AM
miniman82's Avatar
First Light: 1952-2011
I don't think so, but it's hard to tell.
Evolution...
Old 03-19-2012, 11:21 AM
miniman82's Avatar
Steve,
Proto set is on it's way to your door, I shipped it this morning. USPS w/insurance and tracking. I secured it inside the box as well as possible, hopefully they don't manhandle it. I put stickers all over it, so it's pretty obvious the contents are fragile.
Nick
Evolution...
Old 03-25-2012, 09:35 PM
miniman82's Avatar
I made a CRT adapter mask to mate the proto CRT to a CT-100 cabinet, for the purpose of ETF demonstration. It's a board with trimmed 16" B&W mask secured to it, the board has mounting slots cut into it that are correct for the CT-100 cabinet so no modifications are needed. No hole drilling on the cabinet, just R&R the 15G with the proto stuff. I have also decided that having the bare CRT face in the cabinet could be a liability, so for safety's sake I will have a piece of plexiglass cut to the size of the opening in the cabinet to protect wayward fingers from getting zapped. This is what it looks like.
Evolution...
Old 03-25-2012, 09:39 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Nick,
That mask looks good, cant wait to see the tube in operation and see such a historical tube in operation!
Matt
Old 03-26-2012, 06:43 AM
Nick, do you have extension cables to connect it to a CT-100 chassis?
Old 03-26-2012, 09:36 AM
miniman82's Avatar
No, Bob does. The only thing that will be required is the longer anode wire, everything else should reach. Did you get hte chassis yet?
Evolution...
Old 03-26-2012, 02:37 PM
I got the prototype chassis from Nick today and started documenting the remaining circuits. I'm starting with the power supply lines, then I'll do the sweep sections.
I have a new theory about the history of this set. The modifications are very unprofessional, with cold solder joints and midair connections. I can't believe that RCA engineers would do that kind of work. I think the set was abandoned by RCA after its life as a CPA prototype, and the later mods were done by someone who got the chassis, probably an attempt to make it work with NTSC.
Old 03-26-2012, 03:21 PM
kvflyer kvflyer is offline
Steve, your assessment of the "later mods" certainly makes sense. I am just glad that this wonderful piece of history did not get put on the dump as so very many wonderful sets did in years past...
Old 03-26-2012, 08:20 PM
Steve, I agree that your assessment makes sense, although you would be surprised at some of the breadboarding techniques I have seen over the years. We had one fellow (X) who built prototypes by soldering a 3-dimensional haystack of parts onto a tin sheet. (His soldering was good, not cold joints.) Once it worked, he would unsolder all the ground connections from the tin sheet and put the haystack in the cupboard above his bench. These were known in the lab as "(X) piles."
Old 03-26-2012, 09:22 PM
miniman82's Avatar
Good thing he didn't do paperwork, you could have called them "X-Files". LOL!
Evolution...
Old 03-26-2012, 09:56 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Better a well-diddled prototype than dozens of revisions once in production! Ask the techs who test, cal, diagnose and repair them!
Old 03-27-2012, 07:17 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Steve,
So then you will be restoring this as a CPA set? If so is there any chance that at least the sweep and decoder sections could be working by the convention? I can get started on developing a CPA converter.
BTW does anyone have the actual spec for CPA? Can we assume that most things just match NTSC (burst length, phase and position) and only the R-Y inverted every other frame?
Darryl
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 03-27-2012, 08:41 AM
I don't know how much I can get working by the convention. There are lots of cut wires and dangling components. If I can figure out where everything goes I may get most of the set working.
Old 03-27-2012, 09:49 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Darryl
Darryl
Fink, Television Engineering, 1952 edition shows the "color-phase synchronizing pulse" in figure 417 on page 549, which may help.
Pete
