Old 10-07-2019, 07:57 PM
I did not even know I had this...
https://imgur.com/7rYdtgs
playing one of the " The Prisoner " laser discs, I let it run past the end of the credits on the 2nd disc and saw this was there
never know it was there.
It's still hard to get a decent picture, it looks better than this :/
"BUT ... why the "B" on the end???? That's NOT usual, as it means a crimp in the leads." ( ref to prev post)
true, i don't really need the crimped ones.
Old 10-08-2019, 10:51 AM
I guess while I'm in there later, ( with the bottom shield of the IF off) I will replace the 2 detector diodes, (1N60), not that they are bad now, but I hear that they do wear out, and I would rather do it now than later.
Old 10-08-2019, 11:07 AM
freakaftr8's Avatar
Convergence freak!
That test pattern looks good! That's with injected IF?
Old 10-08-2019, 12:48 PM
yes, at the 1st video amp, i lifted up one end of L9 and am feeding in directly in.
I did have to build a video amp, cause composite video is about 1.1 v ptp, and the CTC-16/X wants 3.5 there.
Old 10-10-2019, 09:39 AM
I have always wondered about C70, the ugly white elmenco .001 (2kv) paper cap under the chassis hooked to the plate of Vert output, as of now, mine is still the OEM, as it has not given me any problems... YET...
I'm thinking when I have things apart to fix the IF, to go ahead a change it, but with what, as far as I can tell, as long as it's .001 and 2k (or more ) it should be fine.
So I was thinking of using Mouser # 594-S102K33Y5PP63K5R
Old 10-10-2019, 10:52 AM
I'd replace the elmenco with this https://www.mouser.com/ProductDetail...8ztgyl3M9nM%3D
The elmenco tubular ceramic shell caps are actually paper dielectric caps so they should be replaced with film caps.
Ceramic dielectric caps should never be used in a TV unless the original part was a ceramic dielectric cap. Original ceramic dielectric caps are easy to identify, they are either flat discs with 2 leads exiting the edge or they are thin ceramic tubes that never have a capacitance higher than 200pF...
It is usually best to assume in any tube TV that any cap 1000pF (=.001uF) and up is paper unless it is flat disc ceramic or a later film type such as a Sprague orange drop.
Old 10-10-2019, 11:12 AM
should prob get this one then,
https://www.mouser.com/ProductDetail...F3O1VdC5JV4%3D
as the other one is not stocked and takes a long time to get.
I was looking at the disc-types for a replacement, cause there there were very few film types in stock that met the need, there were more choices in disc, but If it must be film to replace paper, then the choice is clear.
Old 10-10-2019, 12:41 PM
You can also go cheap and use a wima brand... I've used their 6kv parts for replacement of the 6kv paper caps used in early post-war electrostatic deflection sets with success. Their lower voltage parts are probably just as good.
Sorry for the non-stocked link. Navigating mouser on a smartphone is deep in fish out of water territory for me.
Old 10-11-2019, 09:40 AM
Whole bunch a .001 caps ordered for the IF, + ugly one on the bottom, also have the 4 new caps coming for the convergence PCB, & the diode, also ordered this to swap out the 47k res on the plate of the horz blanking amp, (652-93A1A-B28-A20L ) to try to get a little better output from it.
Old 10-18-2019, 11:20 PM
https://imgur.com/Txm8oBx
back on the workbench to fix the IF fail.
2 hours later...
https://imgur.com/4aAYWzG
IF is alive again!
Still gotta change that ugly cap on the bottom and try to get the retrace to work better, and replace some parts in the convergence PCB,
but that's enough for 1 night!
Old 10-19-2019, 12:00 AM
Good work.
You may be coming to appreciate one of the charms/curses of owning a tube color TV....If you use it regularly like it would have been new then it will always need some service work within 6-24 months of its last bench time. Whether it is a charm or a curse depends on how much you like working on it...
Old 10-19-2019, 11:47 AM
dtvmcdonald's Avatar
Good work.
Its a curse. Any rare or valuable TV is very stressful to work on. My blood pressure rises from 120/75 to 148/95 until its fixed. This is by actual measurement. This does not usually happen on radios, though it did happen once when I discovered that the RA17C12 I bought had had all the paper and electrolytic caps already cut out, and the harness cut. This of course ruins my
usual method of avoiding a miswired new cap. [Addendum: well, not ALL of them ... the hard to get at ones were still there.]
Old 10-19-2019, 04:02 PM
it did NOT like this cap as a replacement for c70 :O 667-ECW-H20102RHV
put it in ans lost all vert sweep. put the original elmenco back in, and it worked again , weird...
Old 10-19-2019, 04:24 PM
It only stresses me if 1.) it drops me down to 1 or less working sets in a main viewing room, 2.) if I'm in the middle handling something super-delicate like reattaching a hair-thin coil lead, or 3.) I have a couple of sets disassembled/mid resto that I gotta finish and or reassemble fast to reorganize for something (which I'm sorta dealing with now).
If I let it bug me that bad the number of such sets I have now would raise my blood pressure high enough for my head to shoot off.
Strange that that panasonic cap didn't work...Did you check resistance across it? maybe you got a shorted factory dud or something.
Old 10-20-2019, 11:12 AM
I'm not sure why it did not work T_T
I just know that after I hauled the chassis downstairs, hooked it all up and bolted down ( mistake ) I had I nice bright horz line, till I pulled it out again and stuck the old cap back in. :/
I do not see a short across it, but I don't have a real cap tester here, but have one at work, but it wont test leakage. :/
https://imgur.com/uk0D1qD
It's working OK now, still has IF alignment problems, which has to be fixed sometime I ever get my hands on a sweep generator, this also affects audio slightly ( buzz)
I will attempt to replace the caps/ diodes on the convergence PCB later in the week, which is the reason i have not put it all back together yet and back in place.
