Old 09-16-2007, 04:10 PM
Originally Posted by oldtvman View Post
I worked at an Rca parts distributor as service manager. The most popular tube was the 6gh8, followed by the horz out and damper tubes and of course the 3a3 and 6bk4
When I worked at the local RCA/GE distributor (they were still their own companies back then) we sold TONS of 6GH8A's, usually a sleeve of 5 or more to some shops. We were also a PTS module distributor, and I can remember the top selling modules for most sets - JA modules for Motorola, MAD001 and MAG001/2 modules for RCA, 703644-2/-3/-4 modules for Magnavox, and 9-92 and 9-86 modules for Zeniths. We'd run out and have a backorder on most of these. PTS had a policy of limiting us to 5 each when we ordered.
I also remember selling CRTs - 23VAL/23VAT and 25A/AX series tubes, and the occasional 19" tube. We carried Empire and Channel Master - both great tubes, but man those Channel Master trucks were a B*TCH to unload when the boss bought more than 20 or so tubes. Empire came UPS.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 09-16-2007, 04:21 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
crt's stacked to the ceiling
I remember the area where the crt's were stored, it was a really big area with tubes stacked to the ceiling. The roundies 21jf's and 25axp22's and whatever else.
[IMG]
Old 09-16-2007, 05:49 PM
I remember replacing or repairing the MAD and MAG modules in our industrial RCA Lyceum TVs around 1982-84. CTC68 chassis.
Old 09-21-2007, 12:15 AM
dtuomi's Avatar
dtuomi dtuomi is offline
Originally Posted by Adam View Post
It's good to see that portacolor is still working, I bought that in a thrift store in MI a few years ago, and I don't think I ever even had the back off, it probably still has original caps, tubes and everything.
Well guess what. I shouldn't have said anything. One week later and the Portacolor is having problems with vertical lock.
I don't think its a tube though. I think radiotvnut hit it on the head with the 100 uf cap in the vertical section, but we shall see.
Since he needs work now, maybe he's a good candidate for the dc restoration project...
David
Old 09-21-2007, 12:46 AM
David
I think I confused you regarding the 100 uF cap. That was only used in the '80's GE solid state sets. On your set, I would check:
1. The vertical hold pot. It may be dirty or defective. I think GE had a problem with some of those pots failing.
2. Check / resolder all the connections in the vertical circuit.
3. Clean the tube socket for the vertical tube(s).
4. Check the caps in the vertical sync circuit.
Old 09-22-2007, 12:43 AM
dtuomi's Avatar
I'm wondering about the vertical hold pot on it. It decided to be good today, ran all day without any problems. Do those pots have to be replaced or will contact cleaner do the trick?
David
Old 09-22-2007, 12:10 PM
David
You can try contact cleaner; but, you may eventually have to replace the pot. I had a GE set once that had the vertical hold, vertical height, and vertical lin pots on one assembly. Cleaner didn't work and I had to replace the assembly with individual pots.
Old 09-23-2007, 11:26 AM
dtuomi's Avatar
Thanks for the info.
David
Old 09-23-2007, 11:35 AM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
now you've got me interested. those portacolours are cute... gonna have to be on the lookout for one
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
