Old 03-14-2009, 09:11 PM
cartravision cartravision is offline
Abc
Old 03-14-2009, 09:14 PM
Abc
Old 03-14-2009, 09:51 PM
Abc
Old 03-14-2009, 11:19 PM
Abc
Old 03-14-2009, 11:25 PM
Abc
Old 03-15-2009, 01:41 AM
colorfixer's Avatar
Anything that old, and mechanical, probably has grease that has solidified into a glue. I'd check that first.
Maybe the camera tube has gone bad? Apparently older vidicon tubes suffer from helium infiltration.
Old 03-15-2009, 02:28 AM
Abc
Old 03-15-2009, 02:52 AM
Abc
Old 03-15-2009, 03:29 AM
Abc
Old 03-15-2009, 07:47 AM
leadlike's Avatar
leadlike leadlike is offline
You should have color for your broadcast material. All of your home movie stuff will be in B&W because of the camera. As the cartravision player is such an odd bird, I hesitate to say what the problem is, but you're basically only getting luma signal and no chroma for your colors. I would try to establish a steady b&w picture first. Are just your home movies showing bad tracking, or are your broadcast tapes doing the same thing?
BTW, this is an amazing thread. You're so close now! Keep at it, as you are sure to get this one running!
Old 03-15-2009, 12:40 PM
Abc
Old 03-15-2009, 02:41 PM
Is there a manual in this mix? Might have some directions? Colorfixer mentioned old grease, which is a possiblity even with the NOS machine-it might be running slightly too slow? But I would explore other options first-I wouldn't be quick to tear into that thing. Hopefully somebody will chime in soon who really knows these machines. I do have a friend who is very good with old/odd formats like this, I'm not sure how to reach him though.
Old 03-15-2009, 05:07 PM
Abc
Old 03-15-2009, 09:04 PM
colorfixer's Avatar
pictures like what you've posted are due to either errors in head drum or tape feed speed.
Did these machines record direct color or did they process color "under" like VHS et al.
Old 03-15-2009, 09:23 PM
Abc
