Old 10-17-2009, 12:20 PM
batterymaker's Avatar
Repro Battery Builder
So, I take it the reason there are so many dead 15GP22's is that they were a faulty design to begin with?
Old 10-17-2009, 01:48 PM
But at that time (before Frit was developed) what other options did the CRT manufacturer have for joining the funnel to the panel? Metal tube, welded like the prototypes? other sealing methods?
I have never been able to determine the seal method used on my Westinghouse 22EP22. There is no visible frit bead (frit as we know it today had not yet been developed), and only a faint line can be seen where the funnel and panel join. Solder glass perhaps? Flame seal? Early experimental frit like substance from Corning?
Old 10-17-2009, 01:51 PM
That would logically follow. Not only that, but I would surmise that they were extremely difficult to produce in any case, & prolly had high failure/scrappage rates. Must have been expensive, too. And everything I've read says RCA sold what relatively few the CT-100s they did at a loss-I'm sure somebody was jumping up & down over this, as well as screaming about coming up w/a cheaper, easier to make, better design. Since the CT-100 was only sold/made for a few short months, this may have been the case.
Old 10-18-2009, 02:02 AM
vintagecollect's Avatar
Just an idea, if RACS can find a glass replacement bell for the 15G with similiar size and dimensions, frit or glass weld it to the glass neck and CRT Face,--- wouldn't that eliminate most hassles common of a CRT made part metal and part glass.
Someone NEEDS to look at an Advent 1000A projection CRT as an example. A glass neck, glass bell, glass CRT face w/ phoshor on striking plate. All fritted together and mostly glass.
1977 Zenith Chromacolor II
A Very Modern Zenith
Old 10-18-2009, 11:29 AM
colorfixer's Avatar
The alignment and distance between the shadow mask, phosphor dot plate, and the gun+neck makes this really difficult (~expensive) unless there was/is another tube that used a bell identical to what was used originally without provision for the flange.
The path of stabilizing the ultor flange seal is likely the best way to go.
The bottom line is that the designers at RCA had to make the best of what technology and methods they had at the time.
I'm sure the engineers at RCA would have never imagined that these tubes would be in use some 55 years on.
I'd be curious to see how many modern CRTs will survive 50 years with a vacuum intact.
Old 10-18-2009, 12:19 PM
ohohyodafarted's Avatar
Bob Galanter
Colorfixer has it right.
And on top of what he said will add that the inside flange of the ultor ring is used for mounting the Shadow mask/phosphor dot plate assembly and internal bezel mask.
Even in the extremely remote chance that you could find a 2 piece glass envelope with exactly the same geometry as the 15G, you would still have to figure out a way to mount the internal assemblies.
You need to remember that a 15G is the only color production tube ever made that did not have the phosphor dots deposited directly on the inside face of the envelope.
You would probably have a easier time making an all glass 15" roundie color crt from scratch. I suppose if you had millions to throw at the project you could find some chineese company to make one for you in limited quantities.
The sensible thing to do is follow the course we are already on. It will take time to solve all the issues, but in the the end we will be able to certainly rebuild tubes under vacuum. Leakers are another story. But I think with persistance, we will also be able to solve the issues of sealing the leaks too.
Bob
ME http://AntiqueTvGuy.com
Old 10-21-2009, 08:07 PM
eberts eberts is offline
Originally Posted by ohohyodafarted View Post
jeyurkon:
it is possible that if the getter flashes are very large, we may be able to counteract the infiltration of any small amounts of gas that might get entraped in the ultor ring after it has been sealed.
Bob
Nope, the getter only works on a singular molecular level on the surface it is deposited on. Surface area of getter flash is more important than amount of material in getter. You need a good hard vacuum for the tube to work.
Maybe you could rebuild a tube connected to a molecular ion pump continously, then you won't have to worry about a slow leaker.
Old 10-21-2009, 08:55 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I think Bob did mean "large" in terms of area and not thickness. I believe the getter flash does do better than a single mono-layer, but its pumping speed decreases.
Old 10-21-2009, 09:59 PM
So the problem seems to be sealing the thin metal ring to the thick metal parts.
It has a nice V shaped crevasse that something could be flowed into, seems like Vacuseal should work on something like that unless it can't survive the baking process.
Perhaps if it was a slow enough leak it could be applied after evacuation and cooling were done?
Whatever is used it has to be impenetrable, flexible to some degree, capable of withstanding heat & so on.
I don't imagine there's any way to weld the thin metal to the thick metal without cracking the glass or destroying the seal there.
I knew a guy who could weld aluminum cans together using a Plasma Welder, there's still a lot of heat involved though.
Old 10-21-2009, 10:12 PM
Bob Galanter
You're right Eric,
the problem is between the thick metal ring and the thin metal ring which are fused together in some sort of fusion welding process.
Yes, we have taken advantage of the fact that you can "flow" a sealant into the area where the thick and thin metal meet. Vac seal is not the material of choice. Too thin to fill the voids between the metal layers. It does however seem to endure the heat of the evacuation oven very well. In our first trial, we used vacseal. When we took the crt out of the oven the Vacseal had left a very nice glassy coating on the surfaces that we applied it to. That tube was however not a leaker.
I also used Vacseal to seal some vacuum pumping lines that I was experimenting with and it did not seal the leaks.
Also, I spoke to a fellow in the business of working on UHV eqipment. He rapairs and services HE leak detectors. He had nothing good to say about Vacseal. He did however say that the material we are now using was very much favored by him for sealing leaks.
Oh yes, I almost forgot, one of the reasons that Vacseal is not the first choice, is that it is a solvent base material and it's curing hinges on the depletion of the solvent. This is a very big problem for sealing a CRT. The issue is that as we pull a vacuum on the crt, the Vacseal will have a tendency to outgas it's solvent into the crt. That could potentially contaminate the crt after pumpdown. The sealant we use is not solvent based.
Old 10-21-2009, 10:42 PM
Some amazing epoxies out these days. I really like 3M 8115.
Old 10-21-2009, 11:20 PM
jeyurkon's Avatar
You're right Eric,
I've only been able to use Vacseal on very small leaks. Even conformal coating works better. There are epoxies that use a reactive dilulent, but they're still not as good as the one that you plan to use. They are water thin though which might be an advantage.
Old 10-21-2009, 11:31 PM
jeyurkon's Avatar
One of our welders has TIG welded Coke cans too. It helps to have that level of skill, but it doesn't mean you can reduce the heat in other situations. Where you have to weld is too close to the glass and the rapid heating would be catastrophic.
I thought about suggesting brazing using preforms in a programmable vacuum furnace, but I don't know if the phosphors would survive. I've done similar brazing in a hydrogen atmosphere, but it might react with the phosphor. I don't know enough chemistry...
Old 10-21-2009, 11:35 PM
JB Weld! heh, heh.
Or 3M Weatherstripping glue, that stuff is the most evil crap ever invented, it never comes off!
