Old 10-18-2009, 07:49 PM
Mick AV-8 Mick AV-8 is offline
Philco 41-285 wiring issue
Hi all working to restore my 41-285 Philco console.
Flipped over the chassis to see under the 84 6Z4 socket..to find out there has been some modifications. Running off one of the electrolytics are some soldered in resistors to the 84 6Z4 socket. There was also a pin cut off the tube when remove?
So not sure how to wire it correctly?
I have an 84 tube with all the pins but I wanted to ask if I should cut out the resistors and wire it another way?
And could one of you comment on the correct way it should be wired?
Not so good at reading the schematics..
everthing else seems to be normal but this socket.
thanks
