Old 11-08-2009, 03:26 PM
Dan Starnes's Avatar
Gizmo Nut
Fabulous read!! That cabinet sure turned out pretty. I have used fiberglass resin to pour into molds to create knobs. I will try the JB Weld next time.
Old 11-08-2009, 03:28 PM
leadlike's Avatar
leadlike leadlike is offline
This is it, the final post on the finished product!
I only had to put on the lacquer now, and I used some clear gloss stuff aerosol I got from Home Depot. Four coats later, buffing in between with steel wool, and it was done.
I now only to add all of the pieces to complete it. I had some extra waterslide decals for Zenith, so I put on a Zenith logo and the ABC band label, which was stamped onto the wood in the original. I sprayed a little clear lacquer over them after they dried. The knobs had been lacquered, too, using opaque toner on the edges and face, with a natural finish in the middle. The brass faceplate was buffed up, as the original dark finish was stripped with the grey paint. The grill cloth was some stuff on sale at JoAnn fabrics, and it looks nice here. It is being test-fitted in the picture, hence the wrinkles. To punch a hole in the fabric without it pulling, to allow the speaker mounts through, I used as solder pencil to burn holes into the fabric.
I replaced a few wires on the chassis where the insulation was thin. Before I dropped the chassis in, I looped a wire antenna four times around the inside of the cabinet, and mounted that and the ground wire to a terminal block so the next owner can easily attach an external ground and antenna of their own. Here she is, playing beautifully, the antenna makes a huge difference, I picked up a number of Chicago stations perfectly, and lots of good stuff on shortwave, too.
I handed this set off on Friday to its new owner. He is going to give it to his father for Christmas. He was extremely happy with the finished product. I actually started on this little project back in late September, but I thought I would accelerate things a bit for VK. Thanks for watching!
Old 11-08-2009, 03:29 PM
Originally Posted by 7"estatdef View Post
I'm thinking that the channel knob is going to be challenge. Maybe there is a way to fab a small insert so that it won't want to break off the two flats that turn the shaft. I need to make up afew of the VT-71 knobs too.
So far so good!
Terry
Thanks. I'm think maybe I can scavenge a reinforced shaft from another knob and glue it on
Old 11-08-2009, 03:31 PM
Wow - looks great
You really work fast
Thanks for all the great tips - very enjoyable read.
Old 11-08-2009, 03:40 PM
Speaking of the swirl finish I might be able to help out. For the last 20yrs or so I've been repairing furniture primarily leather and vinyl. With may job I have to create colors and patterns to match these damaged pieces. If you like I could mix up so water based acrylics and I have a good sheen adjustable top coat. Something else that is fun to play with is a doohickey called a mouth atomizer. It's like a bad breath powered spray can that you can put any sort of paint in and spray by blowing. I make a lot different effects with it and a few colors
Terry
Old 11-08-2009, 03:56 PM
Leadlike,
Tnx for sharing!!! It's been great following along and watching you progress on something that looked like a trashcan filler into some thing that may be passed down for a few generations.
Hats off to you !
Terry
Old 11-18-2009, 12:58 AM
coffee123 coffee123 is offline
The sense of self satisfaction when something like that comes so far is frekin awesome! Nice job
Old 11-24-2009, 06:43 PM
Eliot Ness's Avatar
Eliot Ness Eliot Ness is offline
Thanks for sharing your tips on making molds the easy way. The Zenith turned out great, congratulations on a very nice save.
Old 11-24-2009, 08:40 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
We need a separate forum to archive restoration techniques like this.
Old 01-13-2010, 08:29 PM
painkiller64 painkiller64 is offline
Damn! thats some great work on that case!
Looks like new lol
Good Job
Old 01-15-2010, 10:40 AM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
I still can't see any of leadlike's pictures.
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 01-20-2010, 02:36 PM
sampson159's Avatar
sampson159
i do lots of cabinet work myself but not like this one!beautiful job.looks better than new.my hats off to you.
Old 01-20-2010, 10:52 PM
All I can say is WOW! That is a gorgeous radio, you do amazing work!
Old 01-21-2010, 07:52 AM
Indeed, nice save, stunning radio from what many would have passed on as unsavable, great work!
Old 01-22-2010, 12:28 PM
ihmeyers ihmeyers is offline
Great job. It looks beautiful. Makes me think about restoring a couple of my own I have sitting around...
