Old 06-24-2013, 09:44 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Worked on the set a little more this evening. Since it will be a while before I find out if my cleaning of the tuner was successful and the fact that the tuner is hard wired and inaccessible for cleaning without disassembly i decided to make it modular. I added Molex plug for the wiring and an RCA plug for the signal cable. This way, if I need to service the tuner, I can remove a few bolts, disconnect the plugs and remove it. While this is certainly not original, it does make the set easier to service.
