Old 11-29-2011, 03:09 PM
Komet's Avatar
Komet Komet is offline
I have checked the voltages at different points in the set, and I discovered that the 135V (IF and tuner power supply) are reduced to 88. I think it's a defect of one of these capacitors, probably C4
http://imageshack.us/photo/my-images/694/wesk.jpg/
Old 11-29-2011, 04:53 PM
jstout66 jstout66 is offline
Nice set Komet!
I think I have the table-top version, which I just listed in the classifieds section.
Old 12-04-2011, 10:51 AM
Ronce67 Ronce67 is offline
I remember seeing a picture of this set on Shorpy.com- a website of vintage photos. I went back and found it for you. Here is a copy of the text that was with the photo;
"Dad is waiting for the Westinghouse to warm up, and the channel selector is set at 7, WXYZ, Detroit. Other choices were 2, WJBK; 4, WWJ and 9, CKLW in Windsor, Ontario, where we lived. The console TV had doors that closed so that it looked like a piece of fine furniture. The TV was turned on for a show, and when that was over it was turned off. If you tuned in too early in the day all you got was the dreaded Test Pattern. A favourite back then was Detroit's own Soupy Sales. The antenna was up in the attic of our two-story home."
Old 12-04-2011, 05:34 PM
Komet's Avatar
What a beautiful picture! I found this advertising of the Westinghouse italian importer.
I and a my friend have found the cause of low voltage, was mounted a 6V6 instead of a 6W6.
Replaced, I have wonderful video, but low power audio with distorsion and interference with color transmission. Also low snow effect.
Tomorrow I recheck some voltages and all tubes.
Facebook profile
Old 12-06-2011, 04:54 PM
Komet's Avatar
Some progress. I checked if the audio trap is on 5.5 MHz used in Italy, and the interference in the sound is disappeared. Remains the problem of low power audio, I tried to connect my walkman to the volume control and I saw that the audio is low and distorted, the problem is in the power audio output. Tomorrow I check some capacitors, including the coupler capacitor between 6T8 and 6W6 and the capacitor between the anode and cathode of the 6W6
Facebook profile
Old 12-06-2011, 05:19 PM
Reece's Avatar
Reece Reece is offline
Good picture on that set!
Reece
Old 12-24-2011, 08:33 AM
Komet's Avatar
Ok, the distorsion problem is in the audio output section. This is the schematic...
http://img193.imageshack.us/img193/8648/audiowes.jpg
-C69, C1c, C73, C1d tested ok
-C72 and C74, I disconnect it but nothing changes
-R63 was bad, replaced but same results...
-C4 replaced
-6W6 is NOS
-R66, 67, 68, 69, 70 are ok
-R71 ok
-plate voltages ok
-Tried with another output transformer but nothing changes
-My set have a mica capacitor between R67 and the plate of 6T8/C72/R66, supposed for inverse reaction, I bypass it but same results...
I buyed a new 6T8 on evilbay, argh...
With a 2-3Vpp imput, distorsion starting at 10Vpp (2V/div)
Max volume, 25Vpp and 5V/div
If 6T8 is ok, I check the power supply capacitors...
Facebook profile
Old 12-25-2011, 03:01 AM
Giulio Maiocco's Avatar
Giulio Maiocco Giulio Maiocco is offline
Geloso prototype owner
Hi, from my experience, just don't test paper capacitors, put these suckers in the trash bin and [U]replace[U] with new poyester ones, period. IMHO, no paper capacitor is a good one and you'll never find one in any set of my collection.
If you need 6T8's, I have many and can spare a couple too, we are quite close geographically speaking
Cheers
Giulio
Edit: Where exactly do you inject the audio signal? At the 6T8's grid, right? If so, 2 to 3 Vpp at this point is too much. As the grid is only a fraction of a volt negative, you'll need only perharps 1Vpp to achieve full output power, any of the members correct me if I'm wrong please!
Old 12-25-2011, 05:49 AM
Komet's Avatar
I have replaced C73, no results... I injected the signal on the volume control, if on the grid need only 1Vpp my 6T8 is bad... some day ago I have buyed one of these for 1$ on ebay
Thanks
Marco
Facebook profile
Old 12-25-2011, 08:53 AM
kvflyer kvflyer is offline
To somewhat reinforce some of what is said above, one of our beloved members on another forum always said, "If the cap makes a sound when it hits the bottom of the empty trash can, it was bad!" If you have to take one side loose to test it, you only have one other side to remove...
Old 12-26-2011, 03:56 AM
Forgot another thing, Marco: you could use the EABC80 tube instead of the 6T8, so if you have a radio that uses the "european" variant, you could borrow the tube and rapidly confirm or not that the original 6T8 is bad
Cheers
Giulio
Old 12-26-2011, 04:43 PM
Komet's Avatar
I have several UABC80, because italian radios have the heater connected in series. I have put the chassis in the cabinet, I need a pause
Pause = working on a Grundig 5088
Facebook profile
Old 02-10-2012, 05:51 PM
Komet's Avatar
Found the problem: bad speaker
Facebook profile
Old 05-30-2012, 05:48 PM
Komet's Avatar
A friend fixed the speaker of my Westy, probably has been damaged by moisture
Finish
Facebook profile
Old 05-30-2012, 07:12 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Nice set Congratulations on its restoration too.
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
