Old 05-05-2012, 06:59 PM
ShartZenith's Avatar
ShartZenith ShartZenith is offline
CW, is it necessary to remove the flyback winding and recoat it to ensure it works? If continuity checks out okay won't it work in its present state? What are the pitfalls if continuity is okay and I leave it as is? Will it overheat and destroy itself or components nearby?
Old 05-06-2012, 04:01 PM
cwmoser's Avatar
cwmoser cwmoser is offline
I would not remove the winding.
Those wires are fine and fragile.
I would think it needs a coating if the wires are showing - but you cannot use just anything. Perhaps some other folks can advise.
Before going to the trouble to recoat the Flyback, do check for continuity. If a winding is open, that needs to be inspected to see if it can be repaired. There are some folks who have repaired windings but usually its when the open is near the surface.
First step is like you mentioned -- check for continuity on all windings. See if the Flyback as numbers or letters for each wired connection and compare that with the Schematic.
Carl
CW
