Old 11-21-2012, 10:16 AM
consoleguy67 consoleguy67 is offline
60s Throwback
Also a little FYI: The convergence board is on a seperate panel that drops down from the bottom of the set. It has enough wire so you can sit away from the set to see the screen as you make the adjustments. Very convenient! If you need the convergence procedures, let me know.
Old 11-21-2012, 11:55 AM
joemama99 joemama99 is offline
Talking Great!!!
Looks great!I have a 1967 imperial astrosonic with a built in reel-to reel tape deck that really rocks the house.I am sure that one will,too.
Old 11-21-2012, 12:19 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
that set is awesome!! Was there a pic of the remote, or did I over look it?
Charlie Trahan
Old 11-21-2012, 10:21 PM
Bill R Bill R is offline
The convergence board in that is unscrewed from its current position, flipped around and mounted on the two screws along the top of the set. This allows you to see the crt while adjusting it. This is typical of sets, especially RCA and their clones, from the early 60's. I think Zenith was about the most convenient arrangment with the controls behind the speaker.
Old 11-23-2012, 02:32 PM
60s Throwback
I looked at your pictures again; your set has a different chassis then mine.
Old 11-24-2012, 09:15 AM
It looks like a CTC12 to me. Is that a 6DQ5 horiz out.
I didn't think Magnavox built a solid state stereo that early. Especially, one that powerful, to drive that speaker system.
Very impressive!
Old 11-24-2012, 07:33 PM
60s Throwback
The AstroSonic series came out in late 1962.
Old 11-24-2012, 08:35 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Just back from visiting the family over Thanksgiving. The horizontal output is a 6DQ5. The TV chassis is a C39, not sure what the equivalent RCA chassis is. The remote is two button Magnavox Phantom. I just bought a spare remote on the bay.
Old 11-24-2012, 09:38 PM
Charlie's Avatar
On Land
I have one of those Phantom 2-button remotes... the one that blows air?
Charlie Trahan
Old 11-25-2012, 08:42 AM
marty59's Avatar
marty59 marty59 is offline
The CTC12's were the last to use the 6DQ5 tubes and the '15s went to the 6JE6's plus were unique in using a solid state "stick" focus rectifier diode. After that RCA went back to tube rectification.
Old 11-29-2012, 09:00 PM
NewVista's Avatar
NewVista NewVista is offline
Saw a 25" combo today. What year did they introduce the "25" ? (actually measures just under 24")
Old 11-30-2012, 07:32 AM
60s Throwback
They started with 25" rectangular screens in 1966. In my sales book, there is still one 21" roundie combo listed.
Old 11-30-2012, 07:55 AM
hi_volt's Avatar
I believe there was some overlap of the roundie and rectangular set as the manufacturers used up all of the remaining stock of round tubes during the transition. At that time, they priced the roundie sets lower. I think you could still buy roundies as late as 1968.
Old 11-30-2012, 10:29 AM
60s Throwback
From what I've read, Philco was still selling roundie sets in 1968.
Old 11-30-2012, 01:46 PM
DavGoodlin's Avatar
Motorola Minion
Quite correct re the last roundies, Philco had the 17MT80, Magnavox had the T938. A bit earlier, RCA had the CTC20 and GE had the CB-21.
