Old 02-24-2013, 11:58 AM
leadlike's Avatar
leadlike leadlike is offline
Just wanted to throw in my own .02:
If it were my set, I would seriously just leave it all as is. It appears to be unmolested with a decent (though slightly alligatored) finish. It has almost all of its original tubes for crying out loud! I would think it more prudent to preserve this set as "all original" as possible. Maybe find a HO tube that is an RCA from the right era, replace the horizontal coupling caps with what was originally in there, etc. Just to make it as stock as possible.
I just don't feel there is much to be gained from restoring such a rare set. I think the tuner would need to be modified to receive analog signals anyway. With less than 20 of these sets surviving-and all that are documented on the internet seem to have been heavily hacked up at some point; I would think it would be far more important to keep one of these in its 1939 splendor.
Think about it.
Old 02-24-2013, 12:20 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Think about it.
I've already thought about it. On my original post I said I have no plans on electronically restoring this set. I also feel there is not much to be gained from making this set function again. I live close enough to the ETF museum to take a drive over to see one working if I really need to see one function. I am going to make the few repairs needed to the set, replace non-original parts with originals, and call it a day. I have restored sets for display, this will be a non-working original set for display.
I would very much like to find original capacitors to replace the replacements if anyone has them.
Old 02-24-2013, 12:40 PM
Steve McVoy's Avatar
We may have some original capacitors (bad, of course). Send me a list of what you need and I'll check.
Old 02-24-2013, 01:03 PM
vts1134's Avatar
Looking For Time
The two caps in question are both .005 mfd 3,000 volt caps. Bad caps are no problem, as long as they are period correct.
Old 02-27-2013, 06:08 AM
vts1134's Avatar
Looking For Time
Took another long look under the television chassis this morning and spotted two more replacement capacitors, C71 and C73. It appears there was some problems in the vertical at one point or another as well. I'm sure capacitors of this vintage are not your every day item but I'm searching for them non the less. The four capacitors I need are:
2-.005 mfd 3,000 volt (mentioned above)
1- .25 mfd 200 volt
1- .1 mfd 400 volt
Again, these capacitors need not be functional, just period correct. If any one has these capacitors, or just advice on where I might be able to look and find them, I'd be grateful.
Old 02-27-2013, 09:26 AM
tubesrule's Avatar
tubesrule tubesrule is offline
The cardboard sleeved low voltage caps that RCA used were in all of their radios and tv's of the era and are easy to find. Those high voltage caps were only used in the TT-5 and TRK-5 so unless Steve comes up with something the chances of finding originals is extremely slim.
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 02-27-2013, 09:48 AM
vts1134's Avatar
Looking For Time
Thanks Darryl.
I also need a replacement horizontal output tube- 6F8. RCA branded, date coded XE_. I asked my local guy that I get all of my tubes from but he doesn't have any RCA XE_ coded 6F8s. Again this tube does not need to be functional, just needs to look the part.
Old 02-27-2013, 09:53 AM
Here are a couple of pictures. The black and white one is from 1939, the color one modern. I suspect that RCA may have used more than one style originally.
Old 02-27-2013, 10:26 AM
tubesrule's Avatar
Steve,
I think those are the same cap, just a difference in lighting. The high voltage caps always seem to have that dark tan, extremely hard material used for sealing the ends.
Darryl
Old 02-28-2013, 10:28 AM
vts1134's Avatar
Looking For Time
Originally Posted by Steve McVoy View Post
Reproduction pushbuttons are available here:
http://www.renovatedradios.com/parts.html#pushbuttons
There are a number of RCA radios that use similar bezels. The difference is that the TRK-5 bezel uses aluminum pieces around the eye tube and electric tuning light, while the bezels from other RCA radios either have no pieces or have pieces that are silver. It is easy to remove the painted pieces from the old bezel and put them on the replacement bezel, though.
Here are some of the RCA radios with similar bezels:
98T, chassis RC-386A
98K2, chassis RC-386A
97K2, chassis RC-351K
97T2, chassis RC-351K
96E2, chassis RC-351L
96K5, chassis RC-351L
96T7, chassis RC-351L
I received the repro pushbuttons in the mail yesterday from renovatedradios.com. I'll have to fabricate the mounting rod that holds them onto the radio bezel, more on that later. I also need to create the pushbutton labels for each button. Chuck Azzalina's site has a good shot of the labels that he made for his TRK-5.
Has anyone else made labels for a TRK-5, or any of the radio models Steve mentioned that use a similar bezel? Does any one have original labels for any of these models that they could photograph for color and font reference?
Old 03-14-2013, 06:30 PM
vts1134's Avatar
Looking For Time
Progress has been slow with the set, but slow and steady wins the race.
I managed to find a replacement for the only non period correct dated RCA tube in the set. I was hoping to find a 1940 dated (XE_) tube to match the rest, but a 1939 dated RCA OEM tube is definitely close enough.
Old 04-04-2013, 06:14 PM
vts1134's Avatar
Looking For Time
I recently purchased reproduction radio push buttons as they were completely missing. The connecting rod that holds the buttons onto the radio bezel was also missing so I fabricated a replacement rod as well. After installing them onto the set I was unhappy with the results. I just couldn't stand having such a visible part of the set not being original when the rest is almost perfect. Long story short I returned the replicas and started searching for originals. I managed to find them on an RCA radio of the same time period. Here is the radio bezel with the push buttons on it, this picture shows the connecting rod and the snap ring that holds it in place.
It was tough getting all of the push buttons off of the connecting rod as it had rusted a bit. After some lubrication and elbow grease the buttons were removed from the donor radio bezel.
Unfortunately as you can see in the picture one of the plastic covers was snapped in half. I also managed to find NOS push button labels including a "television" label to complete the bezel. I tried to use New York stations that would have been on the air in the 1939-1944 time period. I wonder what station William and his family listened to when they bought the set. I was one label and plastic cover short so I added a KDKA label in honor of the set's new home.
Old 04-04-2013, 07:27 PM
decojoe67's Avatar
The set is looking great! Keep an eye for RCA radios with a good bezel. It's possible. I have come across them here and there.
Thanks for sharing all the pics. I've been a radio/TV collector for many years and the TRK-5 is the "Holy Grail" to me. The TRK-9 has a more impressive cabinet, but it's rather large. The TRK-5 truly has the proportions of a radio console of the era which makes it so great to me. I give you credit for keeping it original. I would be dying to see the set come to life again!
Here's a video on YT of one playing:
http://www.youtube.com/watch?v=VNIkWOa16wo
Old 04-04-2013, 07:54 PM
vts1134's Avatar
Looking For Time
Originally Posted by decojoe67 View Post
The set is looking great! Keep an eye for RCA radios with a good bezel. It's possible. I have come across them here and there. Thanks for sharing all the pics.
I'm perfectly happy with the bezel. It has shrunk a bit and cracked on the upper left hand side around a screw, but other than that it's quite acceptable I think.
I think this hobby is so much better when we all share. I know how much I love seeing pictures when other's share them.
Old 04-04-2013, 08:55 PM
decojoe67's Avatar
I agree that your bezel is fine as-is. I meant to say that you just might come across a set with a perfect bezel (as tough as it may be) for a decent price and you could just swap. I am really looking forward to seeing all assembled! Good luck with it.
