Old 01-11-2015, 09:04 PM
If with the color control up you still get the same bars as in post 20, then what you need to do to fix it is look for the 3.58Mhz Chroma reference transformer, and adjust it's slug until it synchs...At that point the color bars should go away and you should have a color picture, though it might still look a bit funny if the front tint/hue control is mis-adjusted.
Old 01-11-2015, 09:11 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Interesting, color in the pic with the color control turned all the way down when your CRT checks reasonably good. I have been wondering if that was a surefire indicator of a bad CRT because I just got a 1983 Toshiba Blackstripe set that shows a lot of color with that simple test. I don't want to dump it because the person who gave it to me said it was hard for her to give it away because it was her dad's TV. Also, it seems to be a less common model. I might end up stealing a CRT from one that's more common. It has a few other minor ills and could use a Retrobrite treatment as well.
Old 01-11-2015, 09:44 PM
You have a badly misconverged image -the blue lateral is off a bit, but red and green seem converged, giving the yellow lines. The black stuff at the base of the tube is the rtv rubber zenith used to hold the tubes in place for shipping. Dust away the salts and she'll be fine.
Zeno can chime in on this one -I've not worked a Zenith hybrid in a while, as dura module sets are plentiful in my world.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 01-12-2015, 11:02 AM
Good to see it on the bench.
Minor width problem most likely H. output tube.
damper & H. osc tubes also possable and filter can
( in front of tripler ).
The CRT looks very strong. Blue lateral is the white
part on the neck. Has 2 rings with tabs for purity &
the twist magnet is the blue lat. Give that a turn to put
the blue on the yellow. Clean tuner & hopefully the
snow comes back.
Chromatic switch. Note the color, tint, bright & contrast
knobs have holes. There is a second set of controls for the
chromatic. With it on ( orange ) the regular controls dont
work you use the screwdriver to adj it. When off the outside
controls work.
Color problem.
1) clean normal/align switch on top of chassis between the
color module. If that dont work......
2)remove the 2 color modules ( 9-27 & 9-?? ) if the IC's
are still plug in remove them & clean sockets. Be sure to note
the markings to put them back in right. Spray the module
contacts also. If that dont work......
3) put on a color picture. Put norm/align switch in align.
Adjust the APC control on the 9-27 board for the FEWEST bars
rolling through picture. Return to normal.
That will keep you busy for a while !!
Old 01-12-2015, 06:15 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Good news!
After rocking the normal/align switch a little (I didn't even cleaned it) color came back!
I fiddled a bit with the blue lateral to adjust convergence, and voilą! Convergence still need a bit of tinkering, but i'll get to that later.
Now I need to find the focus pot. Looked around for it and I could not locate it. Haha
All in all, I am amazed that the TV came back so easily, you guys where right, those are very reliables TV...and the tube is still very strong!
here are a few pictures, the first is for comparaison to earlier B&W picture, the others are before/after blue lateral magnet adjustment.
And as always : Thanks!
Edit : I just found the focus pot. For some reason it's labeled as "vert. centering" on the chassis, that why I couldn't locate it.
Old 01-12-2015, 06:22 PM
Now that the color is back and I don't have the lines anymore, I probably don't have to go through this precedure, but I am curious : what does a chroma transformer do? does it sync chroma and luma to get a color picture?
Old 01-12-2015, 07:33 PM
It has no effect on monochrome synch. The monochrome horizontal synch pulses contain a sample of the carrier used to detect and decode the color signal. That sample is called the burst, it is gated and used to synch the 3.58MHz reference osc. Tube era sets and some SS sets have an adjustable transformer used to bring the frequency of that osc. close enough for the osc. to synch to the burst. The phase difference between that osc. and the chroma signal determines hue of the color, and the amplitude of the chroma determines how saturated that color is. If the osc. is off in phase people will have purple faces, and if it is off in frequency you will get horizontal bars of RGB, or a constant tinted monochrome image.
Old 01-12-2015, 07:39 PM
Rapid progress ! Nice work. You cant beat these sets to
learn & experiment with.
If the color is lined up properly you should be able
to change channels WITHOUT the color coming on with
color bars before locking in. If it dont deal with it later.
Next is the minor width problem. Be SHURE you are actually
turning the HV reg control, see if it goes from stop to stop.
Most had an odd adjustment that you had to jam a tool in to
get it to move, not just the usual screwdriver adjustment.
HV controls with a bad spot give exactly the minor width
problem.
The filter can is a quick test but the sides are strait so I think
thats OK. After that scare up some KNOWN good ( not tube tested )
tubes. When the width is fixed its time for a complete
CRT set up.
Old 01-12-2015, 07:59 PM
problem.
CRT set up.
Well, there is a slot in the HV reg control and I can see it turning and I hear HV changing in the TV while I do it. Now I don't want to overdrive the TV as I don't have an HV probe, but I rocked it 1/8 to 1/4 turn (cc and ccw) just to see if it does something and it didn't.
As for the tubes, I should get an 6LF6 and the 3 others as well?
Old 01-12-2015, 08:32 PM
dishdude's Avatar
dishdude dishdude is offline
Wow that's a beautiful picture! I'm glad you got it working, I like the console tabletop look the cabinet has. I don't think I have ever seen one in person.
Old 01-12-2015, 10:07 PM
Jon A.'s Avatar
Bravo, nice work. Good to see progress on this one.
Old 01-13-2015, 09:43 AM
The 6LF6 will be expensive but most likely. The other tubes have
no other uses so should be much less. It depends on if you
want to possably wait & pay another shipping charge etc.
Old 01-13-2015, 09:49 AM
Marco-nix's Avatar
I found this, and I wanted to know if it is a Chromacolor or a Chromacolor II? Speaking of that what would be the difference between the two?
Thanks!
Link : http://drummondville.kijiji.ca/c-ach...AdIdZ364245484
Drummonville is near me but I live on the other side od the St-Laurence river.. However, the link is dead. I mean ..non disponible
Old 01-13-2015, 03:25 PM
Of course the link is dead, this thread is 1.5 years old Haha.
Sorry , you where closer to it, but I was faster
Old 01-13-2015, 05:00 PM
Marco-nix's Avatar
No problem
