#31
They need to be changed, but they are not the one that can destroy the set. Every one that goes bad causes the HV to go up by 1KV-2KV. Symptoms I remember are pix not wide enuf & foldover. You may also get arcing at the HV tripler ( big red wire comes out of it) focus pin at pix tube (CRT) socket & HV connector to CRT bell. All in all they cause great stress to the horz & HV components. Best bet is to find OEM replacements. You MUST use the right ones or they will burn up fast. If you cant find OEM there is a capacitor expert here but I dont remember his name. Someone will pipe in & help you with your search. 73 Zeno
#32
OK, thanks.
When searching for new ones, should I search by application, or is there a number on the old caps to use? Al |
#33
I think those caps can be replaced with orange drops (IIRC I've seen it) or film caps of the same capacitance and the same or higher voltage rating...unless there was some special additional component baked in that I'm not aware of.
#34
part ## made by Sprague IIRC. If you dont find them we gotta find that cap expert for a good sub. 73 Zeno
#35
Al Last edited by Retro in RI; 02-03-2014 at 09:45 AM. Reason: spelling |
| Audiokarma |
#36
Also, didn't some sets have a different amount of them, like some sets had three, some had four. It was dependent on the flyback characteristics.
#37
The 4-lead value would have been times the number of them. I think some sets had 4 & some 5 but not sure, been to long. There were at least 3 different 4 lead caps during the Chromacolor 2 era. The very common one, the 13GC10 + and the EFL high angle CRT sets starting from H line. Other brands used them also. Magie had the same problem with CRT necks getting sawed off but it never got publicity. I saw 2 of them. Had the customers bring them to a Magie ASC. Also Sears/Warwick, Admiral & probably other I dont remember. 73 Zeno
#38
The 4-lead cap in the Magnavox had number 250663-XX, where XX was a different number depending on the value.
IIRC GE and RCA also had single capacitors in the sets from the 80s Zenith made it much easier by using one cap, with several in parallel as needed. I have a NOS Zenith 22-5001 and will check its value with my Fluke to see what it is. The reading on both the orange drop and ceramic tube, both 22-5001, was .002 mF (or 2 nF) The working voltage is probably 1600 volts or higher
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 02-07-2014 at 09:51 AM. Reason: Added cap readings |
#39
Al |
#40
& the rectifires on the vert board sometimes. You could take a working one & pull on it & it would come apart. We changed them all if not updated. Maggie was a big long time user of 4 lead caps I think up to the C-1 chassis there best set IMHO. Zenith used them through the 9-160 era at least. I think more would have used them if not for the early problems Zenith had with the American Radionics ones, I would have steered clear to ! Well its always fun talking shop.......... 73 Zeno
| Audiokarma |
#41
for starters. I bet they are getting scarce, its been years since they were used. 4 yrs ago we probably tossed out a mess of them when the shop closed, nobody wanted old stuff then. And IF there is an old (25 years+) REAL TV shop still in your area check with them. They would love to get something for old parts. 73 Zeno
#42
Great idea. Will do. Thanks.
Al |
