Old 05-08-2014, 10:59 PM
bigaudioal's Avatar
Hey guys, one more question about installing the new switch. I have been able to identify all the wiring on the old switch and how it should transfer to the new switch. Everything looks good except for one thing. On the old switch there is a 270K resistor going from pin "A" to pin "D." The only resistor of that value in the area is R501. See the attached close up photo of the schematic. From the look of the schematic, I think that resistor should come off of pin "A" and go directly to chassis ground. Do not see how it would connect to pin "D?" Pin "D" does have a separate wire going to ground. So does the resistor off pin "A" get to chassis ground through pin "D," and because of the dual functionality of the switch this is not an issue?
So I guess my question boils down to, is the resistor off pin "A" okay getting to chassis ground off of pin "D?" Or should that resistor go to chassis ground separately and not connected to pin "D?"
Thanks.
-Al
Old 05-08-2014, 11:42 PM
Thanks.
Electrically it should not make any difference. Any point connected directly to ground is electrically speaking as good as ground to ground to...And just to type it again GROUND.
The only difference between as wired and how you think it ought to be is lead dress and aesthetics.
Old 05-08-2014, 11:43 PM
David Roper's Avatar
console lover
Grounds is grounds.
tvontheporch.com
Old 05-09-2014, 06:16 AM
bigaudioal's Avatar
Thanks guys.!!!!!!
-Al
Old 05-09-2014, 12:17 PM
bigaudioal's Avatar
Nice when an NOS part is ACTUALLY NOS.
-Al
Old 05-09-2014, 01:00 PM
Sweet
Old 05-10-2014, 12:35 AM
bigaudioal's Avatar
SO worth being up late tonight . . .
http://youtu.be/wrBxP-LJ8Yc
http://youtu.be/AUzTZQ77E_E
-Al
Old 05-11-2014, 01:48 AM
Kevin Kuehn's Avatar
Workin' Late Again
Excellence!
