Old 02-13-2015, 11:19 PM
EdKozk2 EdKozk2 is offline
Tinker
Without the 115 volt B+ line connected , your sync pulses can't lock-in
the vertical or horizontal oscillators, nor would the sound work well.
Ed
Old 02-13-2015, 11:37 PM
Tinker
More of the Motorola 19K2
Old 03-02-2015, 10:40 AM
radio nut's Avatar
Born in the wrong decade
ok, I put on tube shields, put the b plus wire back on, replaced a cap that I was told to test and here is what I have. The vertical is locking, the horizontal is jittery, and the image on the screen is a negative image...
At least it appears that way to me and still is washed out like the signal too strong or too weak.
Old 03-02-2015, 01:12 PM
radio nut's Avatar
It was mentioned to check the cap in b plus line to pin 5 of the video amp, which I replaced again to be safe. There is a ceramic cap in parallel with a coil in that line that might also be an issue so i did grab a replacement for it and will try it tonight...hopefully!
Old 04-18-2015, 04:10 PM
radio nut's Avatar
i put in a new cap.....it is in parallel with a 4.5 min coil coming off of the video amp.
the picture is better,but retested the crt and it is shorted............and i do not have a replacement. so this project is on hold for now.
Old 04-18-2015, 04:48 PM
Is it a heater-cathode short? If so just get an isolation transformer for the heater (some 'brighteners' were not brighteners, but rather isolation transformers) or add a separate heater transformer for the CRT.
