Old 10-01-2015, 02:41 PM
SwizzyMan's Avatar
Restoring an admiral c322
I must note that I am only keeping it on for about 3 seconds at the most. Just to see if the problem is still there. But I am still at a loss as to WHAT I messed up. I have been going over schematics and looking for shorts and cant find anything. I will just redo the electrolytics this weekend and see how it goes.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 10-07-2015, 04:04 PM
SwizzyMan's Avatar
Fixed my red plating issue. Broken cap lead inside the electrolytic. Now it seems that my filter choke is smoking!! It is the one beside the 6x5 tube. Still no raster. Could this power supply be a complete loss or should I keep going with it? Anyone have a spare 20B1 combo power supply lying around I can have?
Old 10-07-2015, 04:42 PM
If you had the Cap hooked up wrong originally it might be shorted now even if it's hooked up right.
Can you bypass the switch and power up the PS by itself and see if it still has a short?
At least you would know if the short is in the PS or the Chassis somewhere.
Old 10-10-2015, 11:48 AM
SwizzyMan's Avatar
cant power up the TV without the power supply I think. Anyone else have any input?
Old 10-10-2015, 01:12 PM
I was under the impression the problem was with the power supply?
Of course the short could be either in the power supply or the TV chassis so I was suggesting powering up the supply by itself and see if it still has a problem and checking the output voltages to see if they are correct.
Old 10-10-2015, 01:15 PM
SwizzyMan's Avatar
My bad the power supply is the problem. I cant run the power supply chassis without the tv chassis hooked up since the tv supplies the filaments and other voltages besides the AC to the power supply..
Old 10-10-2015, 04:42 PM
SwizzyMan's Avatar
Also not sure why I can't get a raster.... I have an ultor of about 7.8kv
Old 10-10-2015, 06:08 PM
Everything on this diagram is on the power supply chassis isn't it?
With the power supply disconnected from everything else you should be able to put 120VAC on the primary where the Phono Motor is attached and run the power supply by itself.
If you still get red plating on the rectifier then the short is on the PS chassis, if not then it's further downstream in the TV or radio chassis, it should be fairly easy from there to figure out exactly which circuit has the short on it.
I'm guessing your High Voltage is low because of the drag on the power supply voltage.
Old 10-10-2015, 06:22 PM
El Predicta El Predicta is offline
I may have an extra power supply, will check.
Old 10-10-2015, 06:41 PM
SwizzyMan's Avatar
Eric, You may have missed this but I did solve my red plating issue (broken ground lead on the electrolytic) My problem now is that my filter choke I THINK is smoking. And I can't seem to find out why.
Old 10-10-2015, 07:43 PM
SwizzyMan's Avatar
Also I forgot to mention. I forgot to replace a .002 uf paper cap on the output plate bypass. That could be a potential problem!
Old 10-11-2015, 02:33 PM
SwizzyMan's Avatar
With the power supply disconnected from the TV and the radio but turned on everything seems to be fine now. No smoke, nothing..
Old 10-21-2015, 04:46 PM
SwizzyMan's Avatar
Anyone have a spare 20b1 combo power supply I could have?
Old 10-21-2015, 04:53 PM
If the supply don't smoke running disconnected from the TV and radio chassis, and is producing rated or higher voltage at all outputs, then the power supply chassis is fine. There is likely a short or excessive power consumption in the TV and or radio chassis.
Old 10-21-2015, 04:55 PM
SwizzyMan's Avatar
Will check for anything this weekend. Didnt think I'd have so much trouble working on this.
